Rigid sr2 10 inch light bars installed in 2014 4Runner
cougar428
Hey guys,
Haven't seen this one done yet but my friend and I installed two rigid ten inch light bars behind the upper grille of my 2014 runner. The first thing we did was take apart the the upper portion of the grille which I didn't know was possible. To do that we used this thread as a reference http://www.toyota-4runner.org/5th-gen-t4rs/84880-how-guide-grillcraft-upper-lower-grill.html
It's not for a 2014 but it gave us a general idea of what to look for while taking it apart. After removing the grille, my friend then worked his magic and did a lot of measuring and cutting and ended up making some really nice brackets from aluminum. Once the lights were mounted it was time to decide if we were gonna cut the grille inserts or just leave it in place.
I really wanted max light output and I seen [MENTION=103267]Saker[/MENTION]'s thread that showed how much light he gained by cutting the grille. I was ready to cut the inserts out but decided to do a little test first. We pulled the truck out into the street and we turned the lights on to see how the output was. After that we then put the grille in place so we could compare. To my amazement the output was almost the same as without the grille and you could barely see a difference in the lights output so I decided not to cut it. Let me tell you, these lights are super bright and I am very satisfied with them. Unfortunately I didn't take any output pictures becasue I was too excited and forgot lol. I will definitely try to get some for you guys some time this week . In the mean time, here are a few pictures of the lights
Here are the out put pics
First pic is low beam with 5000k hid kit
Low and stock halogen bulb in high beam
Low, high, and led bars
Pictures don't do these lights justice. They are super bright.
Didi you reinstall all the plastic trim? Do these put off much heat?
yes all plastic trim pieces were reinstalled. As far as heat, when the lights are on you can feel them getting warm but I do t think it's enough to start melting anything.
Clean install!
...and that solves my problem of trying to figure out how to mount a light bar to the lower grill. I never thought of doing a split bar on top!!
Are you Rigid SR2s Driving or Spot?
Also, are there output photos coming soon?!
Hey guys,
Very, Very Nice on the install.
Also, creative on the mounting as well.....I'll steal your install idea if I decide to put some in the upper grill area.
I think center placement of your lights thru the open parts of the grill was the key to you not losing much light....I just lost too much although it was still bright.
I wanted all of the 12,000 lumens output outside of the grill! :lol:
Clean install!
Really not hard to install on the lower part of the grill using your aluminum bumper as your main support, just have to be a little creative.
See my hyperlink in my sig
Thanks, means a lot coming from the legend himself. As far as the clean install, most of the credit goes to my friends Keith and Harvey. They have far superior skills than I do lol.
Could we get some pic's of the output?:pop2:
don't worry it's coming soon. I took some pictures last night but I wasn't satisfied soth them so I'll try again tonight
Thanks for the Kudo's but no legend here....there are some very talented guys on this forum with way more skills than myself.
My write-up was done because I just didn't find any when I started my mod. So I took photos, and wrote it up for a guide to help others.
:dance:
As promised here are some output pictures. I also put them in the beginning with the rest of the pics
Damn! That's a sick setup dude! Does your friend sell any pre-fab kits? Wouldn't mind buying this setup. Can you let me know how much it would be?
I love this stuff! Dude figures out a new place to mount LEDs.
Did you know the reason why we have white LEDS is because of blue LEDs? Then the blue LED was invented by some Japanese researcher that never read the memo you can't make a blue LED? A search is coming up with Professor Shuji Nakamura.
Thanks for the compliments, unfortunately there are no plans to create pre made brackets at this time.
Just looked up this guy on Wikipedia. Pretty interesting bit of information.
Do you have dimension of the brackets then?
Have you considered using the "dual function" H/L SR2?
I have been thinking whether the dual function H/L at the L setting is OK for DRL....
I don't have any dimensions but I'll try and get some for you later. I used a piece of angle aluminum that I bought from Home Depot and just cut it down to size. I seen the dual function lights but I decided to just get the regular ones.
TerryNap61
