HODOR's build and Adventures
lipek
Hi I'm coming from 2007 FJ cruiser in to 2014 4Runner Trail and decided to make a build thread for it especially that I never made one for the FJ.
Previous truck
Current
Suspension:
Front: Icon ext travel coilovers with click adjusters, Icon tubular UCA's, total chaos spindle gussets, MStudt swaybar links
Rear: Metaltech long travel - icon shocks with click adjusters, medium progressive springs and MT lower links, extended steel braded brake lines, MStudt swaybar links
Armor: RCI metalworks skid plates, RCI front lower links guards, FJTOYMAN shock skids/guard, Boztec diff skid, Metaltech trail sliders
Storage: Roof Rack-Bajarack spy system flat rack
Rear Drawer with fridge slide
Wheels/tires: Method Race Double Standard with Cooper Discoverer STMaxx 285/70/17 (liner moved forward and BMC done)
Bumpers: front - HeftyFabworks aluminium version with Superwinch Talon 12.5 sr
Rear - Southern Style Off-road
Lighting
Interior LED bulbs installed
TRS HID headlights
Rigid Flush mounted led in the rear
Flush mounted led lights in the front
OZUSA 40" single led lightbar
Air
ARB twin air compressor
Patches collection
Our first trip happened the first week of ownership. 400 miles on odometer we went for FJNortheasters Turkey Trot/Toys4Tots Drive at Raush Creek offroad park.
I was glad that FJ was my ginny pig as it was slippery and stock tires didn't perform well at all. Other than the weather it was good times.
Relocated rear reservoirs because the tires were rubbing them. Also installed beefy longer rear swaybar links
View attachment 152656View attachment 152657View attachment 152658
good going on relocating the rear reservoirs. that's where they're supposed to be. :thumb3:
ICON should really call better attention to that. i've seen a number of pics of them installed improperly, but can kinda understand why: attaching that bracket to the frame blind (behind the rear body panel) is a real PITA, accessibility-wise, but once it's done the CDC adjusters are still easy enough to reach.
rig looks good.
Thanks [MENTION=29376]sandcrawler[/MENTION] the kit didn't come with directions so I just slapped it together until I figured it was mounted in the wrong place lol
Extended diff/locker breathers in to the jack compartment
Have any more pictures of the relocation of the breathers? I need to do this soon and weighing my options on how I want to do it.
And with the LT rear got to go sway bar less to get the full use of the travel. Even with the new links they are WAY stressed. But on road they should be good.
[MENTION=49966]mikey's2010SR5[/MENTION] I do not, basically run the hoses through the round rubber grommet in the jack compartment, I used AOB kit 4 Port Diff Breather -Air On Board, you will need double sided barbed hose fitting 1/4 " to tie in the e-locker hose with the hose provided with the kit.
As for the sway bars i didn't have them on my FJ and the ride was ok, 4runner is pig and now i tow trailer with it so they're staying on, I migth look in to the quick disconnects for the rear and a "frankenstein swaybar diconnects" for the front (i've seen some company in Cali do them for the FJ's )
Mounted fishing poles using fourtreks vertical mounts and mini quick fists
great work on the rod holder...I'm looking at doing something to hold my rods on top as well. Wonder if I can do something with the stock rack. I notice people use ski/snowboard rack to hold rod as well.
Took advantage of nice weather and installed CBI swingout bumper. Quality and build of it is awesome, unfortunately it did not come with instructions (for the bumper or swingout attachments) and edge dressing. I used [MENTION=107119]2014 Warthog[/MENTION] measurements and instructions, thank you Sir. Also cutoff about 10" from the tail pipe, welded the tip and hanger further back away from the bumper.
Went hiking in Worthington State Forrest NJ, upon return found out Hodor was broken in to. Two backpacks and a sleeping bag was stolen. These scumbags kicked in my window and destroyed almost every plastic trim piece in the process.
Mother bear with two cubs
My buddy's re enlistment
View attachment 155828View attachment 155829
View attachment 155831View attachment 155832
View attachment 155833View attachment 155834View attachment 155835
Damn loser a$$holes. I know the feeling all too well.
At least insurance will cover it. Sorry man...
Bear pic is really cool BTW!
Installed spindle gussets
8th Annual FJNortheasters run at Raush Creek PA was a great success. Hodor behaved excellent and in return received some new scratches dents and pinstripes lol
