The Idiot Thread
Jan 2026 146,500 mi
It's been a while. But sadly my life has been a lot more boring the past few years. But since there's a major repair/upgrade in the works, here's a story.
Icon suspension felt like it was getting soft and the Toyo OC3s were cupped and wearing badly on the inside of the tires. I liked the ride so had Off-Road Addiction of OKC throw on a duplicate Icon set and swap out the leaking steering rack. I then added some Nitto Terra Grappler 3's in LT285 C Load. While this was definitely an improvement, there's still something not right with the suspension. I'm getting way too much sway and wandering into the ruts along with feeling like the back of the truck is trying to outrun the front when accelerating through corners. The 500-mile evaluation happened this week. Looks like the KDSS sway bar bushings are bad along with the rear LCA bushings. As the LCA were replaced with the original Icon install, I expected them to last longer.
I spent some time researching options from OEM to Total Chaos for LCA and there aren't a lot of options for KDSS 4Runners. I settled on the new dual adjustable (Camber/Caster) LCA set from SuperPro. I'm not keen on adding polyurethane bushings that may squeak later, but hopefully they'll hold up better as I'm moving back towards the rust belt in a few months. Special thanks to George in the Cali office at SuperPro for helping me with getting the dual adjustable version that's slated to arrive late March. I look forward to caster going closer to 4.0 deg, as the best now is only 2.6 deg. I was really interested in the Total Chaos LCA, but an extra $1500 to get them just doesn't seem worth it over the SuperPro.
At the shop's suggestion it's time for a trac/pan-hard bar upgrade as well since they can't do better than the 0.4 deg thrust angle from the rear axle. I'd long eyed the Sonoran High Articulation bar for KDSS, and Steve is working on putting one together for me over there.
But that's not all! I ordered a mess of OEM rubber bushings for the KDSS bars front & rear. I made sure to grab the larger 2018+ size and brackets to match, thanks to DrKDSS for that suggestion. From the DrKDSS site come the adjustable end links to help alleviate some of the bad angle that comes from 2+" lift on those sway bars. I debated greatly about the bigger angle adjustment with his front end sway bar angle adapters. But the reality is that $200 is a lot for a couple blocks of metal and some bolts. I expect the adjustable brackets will get me close enough. I also didn't like the idea of moving the sway bar forward the 1/2" those blocks do, giving up some leverage and adding forward/rear travel into the mix.
Next step is waiting for parts to arrive and trying not to beat on the 4Runner too much in the mean time least I develop irregular wear in the new treads too!
Nov 2026 151,300 mi
I'm going to STRONGLY suggest somewhere other than Off-Road Addiction in OKC for 4Runner folks. More than 5 visits to their shop (Jan-May), they never got the alignment near the desired specs or get it even (one side always differed from the other by 0.1 deg or more!). Every visit seemed to request more parts, most of which they couldn't get. Which meant customer supplied parts and a resulting higher labor rate to get it all fixed. I rolled out of Oklahoma still wandering in the ruts on the road and an awkward steering behavior having spent more than $6k on suspension upgrades and alignments plus the hassle of a single driver repeatedly leaving a vehicle more than 30 miles from home.
I moved up to northern Kentucky between Jun & Aug and begged a Euro shop here to fix the 4Runner properly. Less than 30 minutes with the 4Runner and they called with bad upper ball joints: driver's side was on the verge of destructive disassembly, the passenger side not quite as bad but also in need of replacement. Both absolutely something that Off-Road Addiction OKC should have found at my last 3 visits over Apr & May! It does explain the low-speed clunk and alignment issues encountered. SPC billet uppers from the first Icon install made the upper ball joints a simple part swap instead of the whole UCA again. I made sure the shop had the instructions to orient them properly for the desired camber. Alignment finally came out perfect and even! And we're back in business, almost...
Oct saw a return of my escape to the mountains of TN, and before returning home I attempted to add air to the rear suspension to compensate for the added cargo weight only to find that the air bags wouldn't hold air. I drove home blinding the squirrels on top of the road signs. This weekend I crawled underneath to find that when Off-Road Addiction had replaced the rear springs and upsized the air bags, they moved the passenger side air line. The new location allowed it to rub against one of the flanges on the rear axle to the point of failure. It took several attempts and days of wrong size parts, but I finally got some 1/4"OD hose clamps and 3/16" barb couplers for the repair. Reconnected it all and the new bags inflated properly.
The upgraded KDSS sway bar bushings and brackets from Dr. KDSS have made a noticeable improvement to handling, especially at high-speed dodging the idiots who don't understand the left lane is for passing & criminal speeds. Now that it's finally correct and dialed in, I'm happy with the new suspension. I just wish it was a competent shop that had earned the business selling and installing all of it, even if it took a few trips.
Most of the time in the last several months has been unpacking and working on the new (to me) house. There's a list of projects and repairs that seems to get longer by the day. But there's a long awaited mod finally coming for the 4Runner before winter sets in... a heated steering wheel! Stay tuned.
Nov 2026 151,300 mi
for almost 2 years I've been meaning to replace the arb compressor I took out with a new one. haven't even ordered the parts yet. I know that feeling, life happens
Jhunt
