Front Sunroof Drain Exit
gjd
My driver's side sunroof drain is blocked. I've run a wire from the top all the way until it bottoms out under the pillar, but the line still won't drain.
Since the drain exit is above the frame, I'm guessing I need to disassemble the kick panel to access the drain line where it goes into the frame. Has anybody done this? What is involved? Thanks.
