On-Board-Air: Tubing Diagram
TX4runr
I saw the kit that [MENTION=141062]sponsoredbywifey[/MENTION] built for his 4runner. He had a parts list online but not instructions or diagrams of how to install. So I created this diagram along with a detailed parts list. Nothing fancy but should help those that are handy.
I didn't come up with the idea of this system, but I did put together this information! All credit for the parts and idea is to [MENTION=141062]sponsoredbywifey[/MENTION]. Rago Fabrications also sells a kit here:
The "Wifey" Air System – Rago Fabrication
Cheers!
Cool concept. Looks like a lot of potential leak points. Might want to think about keeping the system slightly pressurized at all times to detect a leak sooner rather than later.
Thank You TX4runr. Your diagram was very helpful in putting together my "wifey" system. I've gathered all of the components including the mounts from Rago. Once I get it all installed I will post pics.
Tip: I have been testing the system with a bicycle pump (valve to the compressor closed).
Cheers!
Can you shed some light on how you installed the ARB air hose coupling before it goes into the Wifey system, was this a kit? I can see the two 90 elbows but not ho the coupling is attached.
for all I know this may be sitting in my dual compressor box that I have not even opened yet so pardon my lack of knowledge here. also I'm guessing you're using a bandi mount and its just enough room to clear the hood with the coupling?
Thanks
Cheers!
I’m about to install this on my 2020 ORP (many thanks by the way for the hard work on the diagram!!) and I am using the compressor tray by Rago. One downside I have learned is that in 2020+ there is a relay switch in that same area where the tray mounts, have you heard/seen a workaround for this? Thanks in advance!
What is the need of the PRV on the manifold? I have been collecting parts for building a system, and I'm not seeing the need for a PRV there. The compressor already has one, not sure what I'm missing. Has anyone tried putting a pressure switch that would shut of at the desired inflation level? I supposed the line pressure would have to be less than the wanted PSI so it might not work. Also any reason that a ball valve wouldn't work in place of the hand slide valve?
