Best offset to be flush with 285s
replica9000
On my 2nd gen Taco, I had +10 offset wheels with 285/75R16 tires. I like the look of the tires being flush with the fenders. A 0 offset with the same tires were close and still looked good.
The 4Runner looks to be slightly wider than the Taco. So I'm wondering what would be a good offset to achieve this look? Many aftermarket wheels seem on average to come in 0, -6 and -12 offsets.
I think something with -10 offset and 4.30" backspacing is pretty much dead flush or very, very slightly outside the edge of the fender. Check out some SCS wheel options... they have those specs available with plenty of pictures on this website for you to check out.
What is the point of having 285's if you can't see them? And the farther inset you put wider tires aren't you running a greater risk of rubbing?
Actually, it's pretty well documented on this forum that 285s rub worse with wider offsets, particularly on the front because of the wider scrub radius when turning. Basically, wider offset wheels make big tires hit the mud flaps and front bumper worse.
OP, I agree that 0 offset on a 17x8 wheel is perfect to be about flush, but still under the fenders.
I have 285’s on 17x8.5 with 0 offset and I think they sit completely flush with the fenders.
I know 16s won't fit on the front wheels, but what about the rear? I have a set of 285/75R16s on 16x8 +0 offset wheels. I could put one on just to see how it would look if it fits.
285’s.........
Not sure about offset and all that.., I’ve got the stock limited 20x7’s,
285/55-20’s with 19mm spacers... seems about perfect to me.
the -10 offset of the vtx wheels makes 285s stick a good ways out from the fender
-10mm offset and 4.30" bs on 285/70/17
My SCS wheels with -10 offset and 4.30 backspace are even with the top of the fender. The sides of the lower fenders are slightly in compared to the tire so it all depends on what you call "even". I like this look, but as others have said it will require some light trimming or BMC depending on which UCA's you have and how it is aligned. I had to remove my mudflaps and do some minor trimming on the front bumper and fender liner mod but no BMC.
The pictures make 0 and -10 look about the same. On my Tacoma, the sidewall was even with the top of the fender flare.
So who got some wheels with -10 offset and 4.1 BS?
My (terrible) math had them sticking out a shit load. Now this thread got me more confused.
FX Pro 17x8 wheels with 4.5" backspacing and 0mm offset fit just inside the fenders with Falken Wildpeak A/T3. This wheel is specific fit for 4th and 5th gen 4runners for larger tires and no spacers. The tire design can also impact this some as a tire with a lot of side lugs/features can stick out more at the sidewall and still be a 285 tire.
utkrstam
