VIDEO - Borla 40665 installed - custom side exit exhaust
Soundofmind
Thanks to everyone who contributed to the thread about possible heat issues with a side exit exhaust. I had a question about the proximity to the plastic body parts under the fender. The consensus was there's nothing to worry about.
Side exit exhaust question
Got my Borla 40665 installed today. The exhaust is routed out the side, just behind the rear mud flap. I had originally thought to install the chrome OEM tip, but I went with having it all painted black instead.
Also, check out these video clips highlighting the differences between the stock exhaust and the Borla:
Exterior Video
Interior Video
At the end of each vid, there is a quick A/B comparison. Watch to the end.
Hope it's helpful.
I am actually looking at this for my next mod. I've pretty much decided on Borla. Do you get any droning at all at highway speeds? I've read that Borla doesn't, and that's why I'm leaning towards going that route. Thanks in advance.
How big a difference is it in person? The Borla setup is very quiet in the video, different tone but really no louder it seems, is that what real life is as well?
To many different opinions, one guy in the link above said he switched to Gibson because Borla is too loud? others say its fine, drone/ no drone:shrug:
...Do you get any droning at all at highway speeds? I've read that Borla doesn't, and that's why I'm leaning towards going that route.
DAY 2:
I took a highway trip today to determine if any persistent droning problems exist.
None detected.
There is a *slight* resonance in the cab at 2300-2500 RPM. The Borla has an overall throatier tone and is a bit louder than stock. You can hear it inside, but it's not oppressive. The 4Runner is not known for having a quiet cab anyway. (Once you crack a window, any increase in exhaust volume/resonance is not noticeable) This is a subtle mod.
During my drive, I actually tried to make it drone. At freeway speeds, I found myself between 1700-2100 RPM. The nature of freeway driving makes the RPMs vary quite a bit. It was very difficult to maintain the RPMs in the "drone zone". I suppose if you were climbing a hill, you might be able to keep the RPMs around 2500, but I wasn't able to create this on a flat highway.
As I said earlier, the difference is quite subtle. Exactly what I wanted.
You're right, in the Borla product video, the setup is quiet. But, in real life, it is louder than stock, but not much. You cannot hear any difference at idle.
I hope the videos I linked help to explain.
I have never heard a Gibson in person. But, if someone says the Borla is "too loud", I'm not really sure what they would be looking for. It's not loud at all. If the Gibson is quieter than the Borla, why would they get it?
Hard to describe I guess. If the stock exhaust is a volume 1, then the Borla is a volume 2. Would the Gibson be a 1.5? (Just speculating, I've never heard a Gibson vs. Borla)
No drone.
Yes. This is just a replacement of the stock muffler, with a right angle exit. Not the Borla cat back "system". $$$
I'm not sure I understand, you replaced just the muffler and had the stock pipe bent to come out the side?
I looked into keeping all stock and having the tail come out the side. Two shops wanted ~$350 just to bend the pipe. A catback system can be had for a few bucks more
Yeah you are getting bent over for that price. Must be demographics, in Houston they can be done here at my local shop for 50, chrome tip weld 50, muffler weld 75.
I'll try to clarify:
1. The stock pipe was cut just before and after the muffler. Stock muffler removed.
2. Borla and new hangers got welded in.
3. The pipe going over the rear axle remained in place.
4. That pipe was cut after it turns down. Stock tailpipe removed.
5. New piece of bent pipe welded in and a new hanger was attached to existing aft location.
If you're looking to keep the stock muffler, you only need steps 4 and 5 above.
$350 to do *just* the right angle is madness. Are those shops suggesting that it would take 3+ hours to do it?!? Insane.
Pricing breakdown:
Product - I got the Borla 40665 on Amazon for around $100.
Labor - 1.5 hours for the entire job = $140
~$240 for everything is much less than ~$700(plus labor!) for a complete system.
If you decide to do business with the shops that quoted you those astronomical prices, at least make sure they give you time to get your pants off before they start.:twitch:
Pricing breakdown:
Thanks for the info. I'll defiantly need to shop around. Both shops said the exhaust was stainless and they would need to bend it rather than cut/ weld
I got the Pro XS. It's un-notched.
I believe you are correct. The Turbo XL is just the old name. (It is virtually impossible to verify online. I checked. A lot. Even contacted Borla. You can imagine how helpful that was)
So un-notched is supposed to be for clamp install, notched is for weld on install. I'm sure the muffler shop can weld both on either way. I emailed borla asking which muffler they used for their two 4runner borla kit but [MENTION=51033]97BlackAckCL[/MENTION] confirmed his touring kit is centered on both ends so it will not weld on to our stock pipes if going just for a muffler weld on replacement. I'm pretty sure it would be the same case for the S type kit.
So un-notched is supposed to be for clamp install, notched is for weld on install....
That is the exact opposite of what Borla told me. Here is the email exchange.
I thought I composed a concise and detailed inquiry into their products. The response I got was (borderline insulting) VERY helpful!
Soundofmind:
Hi,
I drive a 2014 Toyota 4Runner SR5.
I have come across two Borla products which both fit my vehicle and I'd like to know the difference between them.
The Borla 40665 is the muffler I'm interested in. What are the differences between the Turbo XL and the Pro XS?
Also, the Pro XS I found indicates that it is "unnotched". What is the significance of an unnotched muffler?
I plan to replace the muffler only, rather than get a whole cat-back system. I want to do a custom side exit exhaust behind the rear wheel. Does this change which 40665 I should get?
Thanks for answering my questions.
Borla:
There is a lot going on here, but I am going to skip to the end. If you think 40665 is the right muffler, then it is.
Notched is for clamping. Turbo XL is just a long case Pro XS.
It seems Borla couldn't be bothered with anything but the minimal level of customer service, so they "skipped to the end". Wow, thanks.
In my research, I determined that the Turbo XL is the "old" name, as you mentioned. I'm no expert on Borla products, but you can also see in the Amazon links you posted that the case size for both the Turbo XL and the Pro XS are the same. Not sure why Borla says the Turbo XL is longer.
Perhaps someone here can verify the actual difference between a notched vs. un-notched muffler.
I just ordered the muffler. I'll post results after I install it. Thanks for the great write up and videos. These vehicles need a little more aggressive sound for sure.
erinobr2000
