ICS FAB Beefy Dash Mount for 4Runner
I might get this. Doesn't block the clock or those who has the accessory meter display in place of the clock. Look like it will work with ram mounts too.
Can you give me some details on this accessory meter? Did you retrofit it in place of the clock?
this one looks alot better and half the price of the mount that i have. expedition essentials i think
Yeah you gotta buy a used or new Acessorary Meter Display and "try" to get the custom harness from user : Old Red. Btw it only works on Trail/Off Road and TRD Pro models.
Well...I just ordered it as well as the usb charging mount.
I like that the clock is still visible with this mount and that it appears to have a bit of a shelf to hold a cb radio to. ( which is my intent )
Will report back when I receive it as well as once I get it installed!
Fascinating...
It definitely looks like a more versatile solution than anything I've seen so far. A nice flat shelf, and lots of room to mount an assortment of electronics. However, I'm a fan of options, so I'm admittedly biased.
Anyway, I understand that a ton of potential buyers will shy away from drilling holes into their dash. Yet, if you want to get your feet wet into vehicle mods... easily-replaceable plastic parts are a good place to start. Better than drilling garbage holes into your drip rails to install a roof rack.
I can't say whether it's well-made or not, since I haven't held it in my hands, but I look forward to [MENTION=194401]macscac[/MENTION] update for more information.
Definitely a good point about easily replaceable plastic being a good place to mod. There are worse ways to screw up drilled holes for sure
I installed mine today and I have to say it’s a very well made product that is quite beefy. I gotta get some more screws for my ram mounts before I get anything mounted to it, but I’ll let you all know how it fairs with some load on it. Highly recommended so far.
Got mine today and installed it.
This is a well designed bracket.
It’s solid and well made. Easy to install and does not cover my clock
(which was important to me)
I need to figure out a new bracket for my CB as the stock bracket makes it sit too high
So for now, just pics with a ram mount for my phone and the USB charging dock
Lots of pics!!
lol its just a truck.
who cares?!?
:D
I just watched the video in the first post and now im kind of thinking about buying it lol.
I'm using a ram mount w/ suction for my ipad mini when i use gaia on the trails but it kind of blocks my view of the front passenger area. this may be a good solution.
I ended up getting one of these, came in the mail yesterday. It definitely feels like a quality unit. Very rugged.
I am very happy with this product.
Can you put up a pic of how you were originally planning to mount your CB?
I have a Uniden 520xl which I have been trying to figure how to mount it on the top middle part of the dash....I think this would do the trick. Ideally I'd use this mounting plate to form a front that I could fab up another shelf off the back of (based upon your "this sits too high" comment), and mount it to the top of the dash. Would have to figure how to hide wires, but obviously just brainstorming right now.
Thanks
Rialm
