My rig is fully armored and heavy. Hefty aluminum front (although may change to a Lil B's full steel hybrid soon) and 4x4 Labs in the rear. RCI aluminum skids minus the fuel tank. Running 285 C's. I have a flat platform in the rear and keep a fridge back there pretty much all the time. No roof rack but run LFD crossbars and an awning. Dual batteries up front and haven't put my winch back in. Currently I think it drives fine. I avg about 15-16mpg combined. On a recent trip from AL to PA doing highway I was getting about 17 mpg. I'm not top heavy so handling feels good and braking is fine with new oem pads and rotors. TBH I think the mpgs are great given how much weight I have. I plan on going to 34's and re-gearing sometime in the future.
Yes I do think it's a slippery slope and once you go rear bumper, especially 4x4 Labs, there's really no point in weight savings. I think if I look back and think my optimal setup between off-roader and on road daily driver it would probably be when I had the C4 lo-pro bumper and 275's. I was getting 18-19 mpg at that time and still took it on some good trails. Adding a rear bumper with swing outs really adds a lot of weight and at least 2-3 more steps when wanting to open the rear hatch. A single half-swing bumper is probably the easiest to deal with. I guess it really boils down to how important you think carry a full size spare is on the back instead of underneath and how many jerry cans of gas/water you need. I'd probably recommend getting a full front bumper & winch first and then the rear bumper when you need it. I've had more issues with approach angle than departure angle but still rubbed the hitch and rear bumper cover a few times.
Well I was thinking I would prob go 34 on my next set since I've cut everything out anyways....
Guess it good to go with a regear... Just another few grand why not...
My 80 series is fully armored and it's a ponderous fuel wasting pig. Yes, you will have to upgrade the springs. Your suspension will also wear twice as fast. Fuel economy is worthless. On road performance is nonexistent.
Have you considered making a Jeep into a buggy that is barely road legal?
My truck has 37's, full steel armor, and regear to 4.88s. I've got no regrets with it's onroad performance, I can daily drive it. Driven it half way across the country, completed the Rubicon trail with no body damage, and drove it back to work the next morning.
If you want more offroad perfomance the weight trade-off is worth it.
My thoughts on the build:
What you do – roads, fire trails, light off roading obviously don’t require hundreds of pounds of armor.
But if you are tearing up the underside, you need armor.
The other option is don’t drive there or break stuff.
Where is the weight?
Roof racks & tents can cause issues.
But you can’t get weight much lower than armor.
I had only been thinking up & down.
I recently went to CAT scales and was surprised with my axle weights.
3000 lbs on front axle
2640 on rear axle
Arguably a rear bumper might actually help me with weight distribution, but I don't really need one.
Spare underneath, prefer day trips or 1-night, don't need to carry fuel.
Spare and hitch take the departure beating mostly.
I guess if I tear something off I'll start looking at rear bumpers.
Suspension:
I started with Tires - to get off road.
Then sliders and skid plates – to get further off road.
Then hybrid bumper, winch & recovery gear – for safety/recovery.
At this point I was heavy and dragging the belly – tearing up the skid plates and rear links.
Once I finally committed to a suspension I’m way higher and drag so much less.
But now I keep thinking about harder trails…
Optimist or Pessimist?
A loaded 4Runner is a compromise.
Not the best on the Road.
Not the best on the Rocks.
Not the best Towing, Hauling, Camping, …. but capable of doing it all.
If you want to do one thing on the list there is always a better option.
If you want to do it all… not really.
You only live once. Build it to be as capable as you want and know it's capabilities and plan and pack accordingly. Also, know where all the gas stations are as well.
If you are going to push the 4R, armor it and do it with less worries about tearing something up.
Well said. Suppose the question is regear first and get it over with or armor up and live with it and see how i feel about regearing after.
Several people have said to put my pedal commander back in. I took it off a while before putting all the armor in.
I would say regear 1st honestly. This is something (if you are anything like me) you will go back and forth about forever even after you put the weight to your 4R. If you pull the trigger on the regear first while the money stash is a little bigger, you will be better off, because you know you will armor up no matter what (or at least that what I did). This philosophy always works for me when I have a few things I am looking at doing. I go ahead and splurge on the questionable mod, because I know in my mind I will make the other mods happen one way or the other. I say up the tire size to 34, go 4.88 and load it down!
Sent from my SM-G950U using Tapatalk
I went exactly the opposite on the FJ. Went to 315s and armor first and plan to regear soon. It’s been a slow boil on the performance degradation but hopefully it will be a nice refresh once I regear. Either way works, I was okay being slow but having protection and then catching up performance when I had the funds. Might be different priorities for you.
I would say I'm at an em-pass for my build. Truck is water tight, full skids, sliders, 33's/wheels, 2nd row delete platform, and a lift. It's a very pleasant to drive on/off-road desert cruiser that I daily.
The stock plastics have all seen better days and I'm thinking it's time to pony up and go full plastic delete. I'm limited to the kinds of lines I can take with plastics. I've bent a fender (minor) on a steep decline into a bit of a hole. I've bent up the rear passenger cab tub doing the same.
There are only so many options for front and rear bumpers resulting in adding around 200 +/- to both ends of the truck no matter what route you go (to include winch and carrier).
I've attempted to contact shops about making lighter bumpers but nobody seems to want the job.
So my question is for those of you that have the catalog thrown at the truck.
What kinds of average MPGs are you seeing?
Have you seen the trucks capabilities off-road be limited with all the weight?
Is the sacrifice in weight worth the ability to bump and scrape with confidence?
