Griot's Ceramic Wax
Johncmng
Does anyone use the Griot's 3 in 1 Wax? I'm getting pretty streaky results. It takes quite an effort to remove the streak on the paint. I have to spray extra wax on it multiple time to even it out. How are you guys doing it?
I just did my AG Pro with the correction cream buffing it. Then applied the ceramic spray. It looks awesome. I had no issue with streaking. Did you apply it outside or inside. I did mine in my garage. Maybe doing it outside is causing it.
I just bought some of that and it streaked like crazy and was tough to remove .
I call Griots CS and told them it sucked . The rep said it won’t work if it’s applied over a sealant . Maybe so but I’ve since thrown the Griot stuff out .
Back to Black Fire Wet Diamond Sealant that works great .
I used this wax and it is easy to apply and buff off while finish looks awesome. I totally would recommend this:
What I did I found out on the you tube guys. You do the correction cream first and then the ceramic spray. It comes out awesome.
Did you do a strip wash beforehand? I’ve also heard hot weather can make it streak.
Yes, I used hot water and Dawn to strip out all the old wax. I applied the Wax on when the car was at room temp (75F) in the shade.
The new turtle wax hybrid ceramic is awesome, easy to apply even in the heat down here. I previously used their Ice and it was pretty good but this stuff is a step up. I've never seen water, not even bead more like ball and roll away. I bet the Meguiars is good as well.
