Front driver 285 70 17 reverse rub
I've got the same issue, only in reverse at full lock. Mud flaps have been removed and fender liner mod done. If you look closely at the body mount, you can probably tell if something has been rubbing against it.
I can see mine has been rubbing slightly there, so time for a bmc or re-locate, but the labor for those has gotten so expensive recently
