Lifted King Suspension
magaca
Lifted King Suspension + Gobi Rack + Light Bar
King Shocks, Total Chaos uca's, Icon 2" lift rear coil springs, 285 70 17 toyo open country at
Looks great!!...could you go into some detail about the difference in handling/ride quality?
I'd love to have something done like this, but I'm afraid it'll destroy my gas mileage, or dramatically reduce handling, as my TE is my DD.
Thanks for any input,
Pat
thanks for your comments, as to handling to soon to tell, but drove like 10 miles on freeway and felt great almost the same probably less body roll (to soon to tell) and a little stiffer on small bumps the rest great so far, also speed reading did not change due to tire size i put a garmin gps and the speed reading was the same, i will update information on handling and overall feel etc later, so far i'm loving it, looks great also, i parked outside costco and when i came out there was a guy taking pictures with his cell
Ok pardon my ignorance how come everybody who puts coilovers on does new UCA's? Due to the more travel provided by the coilover and more alignment adjustablty? Looks good though
That's pretty much it. Aftermarket UCAs typically provide:
  • A bit more alignment adjustability
  • A bit more travel due to better designed ball joint
  • A bit more clearance between tire and UCA
They typically aren't required unless you run into an issue with any of those 3 items. I think camber adjustment is probably the biggest issue with many of the taller lifts. (Similar to lowering a sports car, camber often becomes a problem.)
Ok thats what I thought I read up alittle first but thats all that came up. (I actually had to put a camber kit on my wifes old Honda we lowered)
I would love to see some pics of the rear shocks. After seeing your setup I am going to do the same thing. Those look mean. I don't plan on jumping my car or having the shocks get that hot, but those look mean.
Aren't After market arms most typically used to correct caster issues with the alignment? I know the Light Racing arms can add extra camber, but most non adjustable upper arms just add a few degrees of caster since a lift of 2.5"+ will often have caster alignment readouts of less than recommended.
Most Upper after-market arms will allow for extra suspension droop like you mentioned to accommodate extended travel Coilovers, but I don't think they all allow extra travel. I think some will bind up, not sure which ones though.
Magaca, Lift looks Awesome!! That suspension should take everything you throw at it and still beg for more!
thanks, i will post better pictures in a couple of day
new pics with rack
You've got great taste in mods. I may be a little biased though :)
How is the light output on the bar? Is it a VisionX Xmitter? Did you have to modify anything to mount it? Some of the FJ guys had minor fitment issues.
its vision x, i sent the measurements of the light to Gobi and they did the mount specifically for that light at no extra cost they were great, they even gave me the option of sending them the light and they would mount it, i read somewhere on this forum about someone complaining about the service in Gobi in my case costumer service was exceptionally good
Very Cool looking Rig :bigok:
How did you mount the remote reservoir up front ? King sent me the new bracket that mounts up to the sway bar location, i am worried that this will interfere with the KDSS and washer fluid reservior
thanks for compliments, i did not do the install myself but on monday ill ask the guy that did the installation and let you know but i'm sure where he put them it does not interfere with the kdss but on drivers side i am getting some rub with tire ill let you know
Bunkstaff
