Has anybody done this before?
TMAC110
well, i kinda made a little spur of the moment decision and bought myself a 1st gen roll bar that i got for 20 bucks :biggrin2:. I've seen a couple runners that have it installed but most of them are 3rd gens. So... how many of you guys have done or seen it done in a 2nd gen and know of any tips or tricks to make the install maybe go a little bit smoother?
Nope, can't be done. I'll dispose of it free of charge. Aren't you glad you have such a nice roommate? :cheers:
It was quite a bit of work to get it to fit but once we got it in i decided i liked it so i think ill go ahead and keep it :banana:
This may sound re****ed but how did you get your backend so flat?? Does the bottom of the seats pull forward? (i've never really looked at it, but it looks like it does)
fourwd1:
i actually didnt use steel plates for it, i cut the mounting brackets off of each leg and then cut the legs down and re-welded them back on and then used that and mounted it straight to the body with 1/2 inch bolts with some butyl in between to seal it up so water and stuff cant get in. it almost seems like it could be factory!
SilentYoda3:
yeah the cushions of the rear seats fold up and then you just take out the headrests and push the seatbacks down and it should be flat.
I like it if I had the tools I would totally do this. I dont want holes in my truck though either.
patnewton
