RS3200 Question
Mark86
Super Moderator
I have the stock alarm system that the 2003 4Runner came with (the remote with the three buttons). I wanted to test the alarm and hear what it sound like, so I hit the lock button and left the driver windows down. I then went and opened the driver door and there was no sound. I tried it again and there was no sound. I hear the beeps when I open and close the doors and I hear the horn honking when I hit the panic button. How do you get the alarm to make noise when it is set and a door is opened? Do you have to wait a certain period of time before it activates?
SR5s and Sports do not have a standard euipment alarm. There were two available alarm options. A basic alarm and the RS3200+. Regardless, both work the same and are activated when you close and lock the doors.
All 4runners have the beep associated with locking/unlocking the doors, the horn/panic feature, and the 3 button remote. Based on your description, it sounds like you don't have the factory alarm.
I did not do anything with the car regarding an alarm. This is what the car came with when I picked it up. I thought the car should at least go off when a door is forced open. :confused:
If you have the same one I had....
On the center console by the clock there is a little red
car that will come on when you lock the doors.
If you have that....
You have to wait like 30 secs for the alarm to activate
then try what you said.
I believe all 4runners have the little flashing CAR light. It's used by the keyless entry system and also used by the integrated factory alarm (if you have it). If you close and lock the doors with the key or the buttons and then wait 30 seconds, your alarm should go off if you reach through the window and open the door. If it doesn't, then it's either disabled, malfunctioning, or you simply don't have an alarm.
The easiest way to confirm that you have the factory alarm (but not the RS3200+) is to look under the hood. The factory alarm includes an extra horn. It's mounted between the passenger side fender and the air filter box. If it's not there, you willl just see the 1 pin connector where it goes. If you have that horn, then you have the alarm. If not, then you may have the rs3200+ or no alarm at all.
I do have a little red car flash when I take my key out of the ignition. I did not wait 30 seconds when I did my test. I will definetely try that tonight.
Was the RS3200+ an option when you bought the car or did you have it installed? If it wasn't listed on the sticker and you didn't install one after you bought, you don't have it. All 4Runners come with 2 remote "keyless entry" remotes. They do just that, lock and unlock your doors without a key.
The red car with the key in the middle is just the immobilizer system. Once you remove your key from the ignition, it starts flashing and is standard on all 4Runner models.
The RS3200 is not listed on my sticker as an option and I did not have it installed as an option. I tried the 30 second thing and the alarm did not go off. What is a good alarm where it goes off when the doors are forced open. I do not really need a glass sensor. Oh well. Dealer told me that all 4Runner's come with alarms. :bonk:
Ummm pretty much ANY alarm will do that. You can still get the RS3200+ system. They are available on-line and via ebay for around $200. If you go that way, it will work with your existing remotes and the red light already on the center console.
For the same money though, you probably can an alarm with more features. Or you can just get a basic alarm for less money.
My ride came with an alarm but it was one that the dealer pre-installed. It was one made by Code Alarm and was able to work with the factory remotes. It had it's own LED also. It was annoying since it honked the horn every time I locked/unlocked the doors (in addition the chrip of the keyless entry system). Worse still if I left any interior or lights or the headlights on, they would trigger the alarm when the automatical light control system (standard feature of all 4runners) turned off the lights. I yanked it and gave it back to the dealer (since I never paid for it anyhow).
I have on order an RS3200+ which should be coming today. I'll let you know what I think of it. Again, I know there are better alarms for the money but I wanted something oem.
Sorry you were mislead about having (not having) an alarm system in your truck.
i added the rs3200+ to my 02 with keyless....straightforward plug & play deal as wiring is already there for everything......hopefully its similar to the 04 installation.....yeah you could get a whole lot more features with aftermarket stuff, but if you prefer to keep everything oem, cant go wrong with the rs3200+....
if the theives REALLY want the truck, they'll get it:mad:
All 4Runners come with an ANTI-THEFT device but they all do not come with alarms. SR5's and Sports come with a anti-theft engine immobilizer which basically disables the igntion should someone break in and try to steal it (they need a toyota key). The Limiteds come with the above plus a full blown alarm system with a siren. The alarm system/siren is an option on SR5/Sports so it would be listed on the window sticker if you have it.
Both systems use the little car/key symbol in the center of the console. The owners manual describes how each system works and how the keys work.
Sorry the dealer mislead you. One would think a 30k truck would come with an alarm system of some kind. :)
Keep us posted on this, I'm going to get one soon and install it myself. Just want to know if you run into any complications.
I said the same thing to myself when I found this out. You pay over $30,000 for a car and there is no standard alarm. When I spend that kind of money, I want to know that my car is secure. I know of cheaper cars that come with an alarm. :thumbdwn:
tkr128, I will definetely keep you posted. I will pursue this the next time I go in for service, which will be around the middle of next month.
Well your car is secure... no one can drive it away.
Sirens/alarms provide a false sense of security, when was the last time you went and checked on a vehicle whose siren was going off? Most likely by the time you even got there the thief would be in and out with your radar detector in hand and no one saw him. They actually provide no security for the vehicle, all they do is make noise if someone tries to break in. The stock anti-theft that comes on the 4Runners provide more security than any siren. If you want true security get some bullet proof glass.
I'll replace some plastic trim and a radio, but they aren't getting the truck.
It's true, the engine immobilizer (standard feature on all 4runners) is the real protection for your truck. The loud and obnoxious alarm offers some protection for your belongings thought I agree, it's not much. Regardless if you have one or both systems, an intent thief CAN drive it away, if he really wants to.
Dealer told me that insurance required all the cars on their lot to be equipped with alarms and that they would charge me for it unless I signed the paper having them tear it out. Ended up having them leave it in there, it's made by Karr. I'm guessing it's the optional standard alarm? But it doesn't show up on the sticker as an option.
If you are going to add an alarm.. i would recommend the Toyota one. As someone else mentioned.. it is really easy to install.. all the wiring harnesses are there.. you just plug it in. Plus... it will work with the immobilizer and the remotes you already have.
The RS system was an option on the Sport.. i got lucky and it was added to mine (it is on the sticker.. i should look to see how much i paid.. i am sure it wasn;t cheap!) I tried teh whole "roll down the window, wait, open the door"... i think i woke up everyone up when the alarm went off.... opps.
For my 1998 SR5 i bought the Toyota alarm form JayMarksToyota/ToyotaWorld. They gave me a great price, so you might want to check them out.
cheers. -g
If it's not on the sticker it wasn't installed at the factory. If it's made by Karr it's almost certainly not an OEM alarm. The optional RS3200+ is made by Fujitsu Ten. I'd bet the optional standard alarm has similar origins.
I know that all 4Runner's have pre-wiring for the RS3200+. Where is the exact location for that wiring and how long should it take to install that alarm? Also, is it hard to get to the pre-wiring? I am not sure if I should attempt it myself or have the dealer do it for me.
