Viper Remote Start?
benk777
I would like to add remote start to my 2005 4Runner Limited, but I wanted to check with you guys first. Would the 791XV work? I don't want to foul up any of the electronics in the vehicle, and I'm not sure if there are compatibility issues. I'm sure the installers at Best Buy would ensure me that any system would work, but I don't trust them as far as I can throw them.
Let me know your thoughts.
Thanks.
Ben
The 791xv is outdated.... You'll want the 5900. Basically the same system just with the SST technology = longer range on the 2-way remote. You'll also need a transponder bypass to trick the ignition into thinking there is a key in it. It's about another $50 and the part number is XK05. They are made by directed electronics as well and the company is Bypasskit. website
I had Viper 5900 installed at Best Buy. Great alarm and starter. Best Buy guy installed it a year ago and no problems at all.
Alarm is sensitive. I had it going off when someone threw a ball at the car. I also bought extra backup battery that best buy guy installed. There are bunch of additional components you can add to the alarm, it is in the manual. I also had rear window programmed so it ca be opened with the remote.
P.S. Best Buy guy kept original security in the car, so I can unlock the car with the original factory remote, but it goes off, so I have to use Viper alarm to disarm it.
And 2 mile remote range is also nice.
So overall, I am having great experience with the alarm and starter. Go for it. But make sure you are not installing it at Mom and Pops shops, I've had bad alarm and starter installation experience with my 04 Honda. Better go with Big Store name so they can honor their lifetime installation guarantee.
First off, to give some credentials, I've been a Master installer, MECP certified, and done installs in thousands of vehicles over the years. (Just so you know I'm not talking out my ass.)
The Viper security packages are designed around a Toyota vehicle's electronics, believe it or not. Meaning, the Toyota line is the first one to undergo testing from the R&D facility at Viper. This is due to the advanced electronics in Toyotas that usually leak down to the domestic market far after Toyota has improved on the design already.
Viper designs them to work around the stock alarm systems, locking systems, and all other stock options. If installed properly, nothing should ever show a sign of conflict.
In the car audio industry, we frown upon Best Buy and Circuit City's installations, due to an abundance of shortcuts and money-saving performance-compromising parts. However, each individual location must have one installer, the "master", who actually knows what he's doing. Talk to him before allowing them to install. If you're nice to the installers, they'll usually NOT skip on the "optional" steps, like setting sensor gain and programming options that are usually "not included" and can be very hard to do without a background in automotive electronics. Still, for most people, these retail install shops will operate and install fine. Circuit city installs RADIOS better than Best Buy, typically, although I'm not sure about alarms.
So, in summary:
-If installed right, no stock electronics should be harmed or cause problems. You should also NOT lose any original features.
-Retail installers are fairly cheap, and moderately reliable, but trade secret of talking to the master installer first usually will get you a better install, or even a discount on time.
And yes, I'd go with the best Viper alarm you can afford in your budget. Viper is a great product line and has good quality control measures.
Hope it helps! Feel free to message or post reply if you have any questions I might be able to help with.
-Tom
I am working on putting a compustar unit in my 4runner. I would not use the XK05 bypass. I originally bought that and it is a PITA. I wired needed extended on both sides and there is a lot of hook up. I ended up going with a fortin module. Only 4 wires to hook up to bypass the immobilizer and they are all at the column.
DEI 1100X for the bypass
Also, the Viper 5900, Python 990, and the Clifford RS50.5X are virtually the same alarms. So if you find one a bit cheaper than another, go for it. Just as the Viper 791xv, the Python 881xp, and the Clifford (can't remember that model number) were the same.
Here's a good link for alarm recommendations:
http://forum.sounddomain.com/ubbthreads.php/ubb/showflat/Number/1253953/page/1#Post1253953
Of course, back it up and read more about general security questions:
http://forum.sounddomain.com/ubbthreads.php/ubb/postlist/Board/9/page/1
