TotalAutomotiveLV
HPS High Temp Reinforced Black Silicone Radiator Hose Kit is designed to replace the stock OEM rubber coolant hoses which can eventually weaken over time, leading to premature failure. With premium quality silicone and race inspired design, this HPS silicon radiator hose kit can withstand the harsh high temperature and high pressure operating conditions of the engine yet still maintaining peak efficiency during offroad adventures or daily driving.
Key Features:
Stay Cool - Old cracked or split radiator hoses are not efficiently cooling your engine which can cause it to overheat leaving you stranded. So maintain your FJ Cruiser cooling system by replacing your old brittle hoses now before it's too late. Perfect for racing or daily driving application.
Direct Fit - HPS silicone radiator hose kit has all the correct bends and curves for a perfect fit replacement on your FJ Cruiser, it is not a cheap one size fits all universal hose you get at the local parts store that you have to fight with to install.
Premium Quality - HPS Silicon coolant hose kit is made from multi-ply premium grade silicone and reinforced with high-quality polyester for which reduces the risk of component failure and enables higher temperature and pressure to be maintained with complete confidence.
Technical Specifications
Temperature Range:- 65 deg. F to + 350 deg. F (177 deg. C)
Color: Black
Material: 3-Ply Reinforced High Temp Silicone
100% Stainless Steel Clamps are included for easy installation
Fits 07+ Toyota FJ Cruiser
$127 delivered to you! (Lower 48 States)
Black - 57-1206-BLK
Blue - 57-1206-BLUE
Red - 57-1206-RED
Key Features:
Color: Black
Black - 57-1206-BLK
Blue - 57-1206-BLUE
Red - 57-1206-RED
