I have an older Samsung tab 3 and was thinking, is it possible to use it as a GPS if I downloaded topo maps?
Im sure Im over thinking this lol
@%1;
You will need wifi for it to work.
not unless you can download the maps to your sd card in the tablet.
Then it is just a map on a tablet.
OP asked if it could be used as a GPS.
Yes you can use a gps. Go use google maps and they will let you download a select of your map and you could still use gps if its in the area of where your map is downloaded.
I download offline Google maps to various devices. Google time limits the maps for 30 or 40 days. Works great. Your Tab 3 should have no problems with offline maps. Have not used offline topo maps. There are a couple of vendors in the Google Play store.
Offline Google Maps also help your everyday device find and lock on faster with cellphone coverage.
If your tablet has a gps chip, then yes. I use my old Nexus 7 tablet with Gaia topo maps all the time and it works great. Download the maps before hand and you are good to go.
just to be clear, a stock tablet will work for GPS, it will triangulate off the wifi card. if you go off road, there is no wifi. without a local wifi to triangulate to (actually 3 or more), there will be no gps.
a gps chip should get you to within 10 meters, wifi triangulating in a remote area may as much as 65000 meters, but again that relies on a well known fixed wifi spot, the more its reported the better it gets
I would hate to see you going out with a wifi only tablet and get lost
