Is it possible to use tablet as trail GPS?
04rnr
I have an older Samsung tab 3 and was thinking, is it possible to use it as a GPS if I downloaded topo maps?
Im sure Im over thinking this lol
Then it is just a map on a tablet.
OP asked if it could be used as a GPS.
Yes you can use a gps. Go use google maps and they will let you download a select of your map and you could still use gps if its in the area of where your map is downloaded.
I download offline Google maps to various devices. Google time limits the maps for 30 or 40 days. Works great. Your Tab 3 should have no problems with offline maps. Have not used offline topo maps. There are a couple of vendors in the Google Play store.
Offline Google Maps also help your everyday device find and lock on faster with cellphone coverage.
I stand corrected. Learn something everyday.
Its been years, but I used to have Backcountry Navigator when I had an Android phone. Check it out.
Also, EXPO and ADVrider have great GPS resources.
^^^This is what I do. I've used downloaded google maps on my iPad and it has worked well many times, in many places, when I had no cell service.
I do stuff like this for a living, I have a mobile app that runs on a tablet...
you will need a gps chip in the tablet, while it can use wifi to triangulate, since you are going to be in the woods, if you even have a wifi signal, the location may not be well known (your phone will use the wifi strength and the gps or agps chip in your phone to locate the wifi signal and upload that info without you knowing, this is how the location gets to be well known).
if you have a gps chip, then yes it will work but as others have pointed out you will need to download maps.
now, if you have built in nav, you could set a start point and turn on the bread crumb feature and use that. not perfect but it will work somewhat
The tab s2 I have runs BackCountry Navigator PRO, works great. It has GPS.
Like these guys said you just download the maps you want to use when your out 4wheel'n.
Avenza Maps is nice for OHV area maps.
I use Backcountry Navigator Pro with AccuTerra Maps subscription on my Samsung Tablet. It's wifi only but still has GPS features. As long as you download the area you're going to before hand on the device or on a memory card it will work great.
If your tablet has a gps chip, then yes. I use my old Nexus 7 tablet with Gaia topo maps all the time and it works great. Download the maps before hand and you are good to go. They have many different layers and you can plan your trip on their website on advance and sync it to your tablet. It's pricey though at $30/year I believe.
The apps others have stated will work fine too, just make sure your tablet has a GPS chip and you are able download offline maps.
Sent from my ONEPLUS A3000 using Tapatalk
Fo sho
I also use Gaia GPS on an old iPad (no cellular) and as long as I download maps in advance, it's fantastic. With GPS alone, it's plenty accurate for our purposes.
I've found the yearly subscription worth the $30 as it offers dozens of layers to choose from (such as Nat Geo and USFS MVU maps, among others).
just to be clear, a stock tablet will work for GPS, it will triangulate off the wifi card. if you go off road, there is no wifi. without a local wifi to triangulate to (actually 3 or more), there will be no gps.
a gps chip should get you to within 10 meters, wifi triangulating in a remote area may as much as 65000 meters, but again that relies on a well known fixed wifi spot, the more its reported the better it gets
I would hate to see you going out with a wifi only tablet and get lost
Couldn’t you “hotspot” your phone and then run the tablet off your phone’s GPS?
Just FYI. I use a old iPad mini with Gaia maps. As stated above, I just download the map area before heading out. My iPad doesn’t have the cellular/GPS chip in it. I use a Bluetooth GPS from Amazon to fix that problem and it works great.
Dual Electronics XGPS150A Multipurpose Universal Bluetooth GPS Receiver with Wide Area Augmentation System and Portable Attachment https://www.amazon.com/dp/B006M49G80/ref=cm_sw_r_cp_api_TiBGAbC6MNNBY
BillM777
