Any pics of your rig with a 1" spacer lift?
G.I.G.
I've done a bunch of searches for 1" leveling spacer lifts, and I can't find any pics of a 4R with just the leveling kit. It seems like the 2/1 and 3/2 are more popular, but my 4R won't fit in my garage with my snowboard rack with any taller lift than the 1".
Does anyone have any pics of their 4R with just a 1" spacer lift, maybe with one size larger tire?
Here you go... 1" toytec spacer on the front.
Very cool, thanks for posting those pictures. I think that is the convincing I needed to pull the trigger.
Did you have to re aim the headlights and fog lights after you installed the lift?
So, when are you going to get bigger tires? :)
I had to point the headlights down just a bit, but the fogs I left alone, seemed like it lit up the road better unadjusted. As for the lovely Dunflops I have about 4/32 of thread left so they'll be replaced soon with up sized Revos 265/70/17. The factory size tires look a little funky on the 4R, I wonder why Toyota decided to use that size.. :confused:
Do you happen to have the part number for those by any chance? I called my stealership and they said I can order Toytec spacers through them. I might try to work a lift into the deal for the "incident" I had with the dealership the other day. :mad: See my other thread....
http://toyota-4runner.org/showthread.php?s=&threadid=41626
I was also curious how long you have had them installed. Any noise or difference in ride quality? Any difference (good or bad) off road?
The part code is "TOP1-T", it sells for $59.99. The spacer measures 3/8" but with the suspension's geometry (leverage ratio) the end result is 1 inch of lift. Their web site is www.toyteclifts.com. I've had the spacer on for almost 2 years 15K miles with no problems, as for ride and handling it feels the same as stock. Yeah, I saw your other thread with the incident at the stealership, that sucks big time hopefully they'll get your Runner back to new.
front lift pics
lift is from www.extremetrucktoys.com i cant get the pics to send it tells me theyre to big. i have my camera set to the lowest resolution for email and it still is to large. sorry check this web site out. ive had the lift in for 14-15 months now with zero issues.my sport has the exreas on it also.
The Cornfed spacers look exactly the same.
They are a 1/2 inch spacer , which provides 1" of lift , so I'm told.
I dont understand how a 3/8 spacer and a 1/2 spacer would provide the same lift. The 3/8 looks slightly higher, looks great though !! , once you get some 265/70's on there it will look really sweet.
You know what, they are 1/2" not 3/8. My bad... Yes these spacers are similar to the Cornfeds but for half the price..
I should be getting my 4R back from the dealer within the next couple of days with the Toytec 1" spacer lift installed. I will post pics when I do....
The dealer is doing it ??
Thats pretty sweet.
They must be cool with them .
