I have a hobbs hour meter I wish to install to keep track of engine (on) hours. My initial thought was to wire it into the oil pressure circuit however I do not have access to a wiring diagram for my 06 V6. For this circuit to work, the oil pressure switch should be normally open and closed when oil pressure is present. This would give an accurate hour measurement without false times if I were to just wire it into an ignition switch ON circuit.
My other thought was to tap power off the fuel pump circuit
Can someone with access to wiring schematics tell me how the oil pressure switch is configured? or suggest a decent circuit to tap into?
Much appreciated.
JL
Much appreciated.
JL
