05 4Runner starts and then dies
Nolaninthebox
I was driving to work the other day and my car shut off while I was driving. When I try to start it, it starts like everything is okay and then dies immediately. So far checked all the fuses and relays, replaced maf, new fuel pump, and replaced the ignition. Any suggestions would be appreciated. I also can’t find any cracks in the air hoses. Only codes are p035x for all cylinders.
Don’t know anything about codes but quick google search, AI says ignition coils, have you replaced them.?
This is what the internet says...
If all cylinders are showing P035X codes simultaneously (e.g., P0351, P0352, P0353, and P0354 all at once), it is highly unlikely that every single ignition coil failed at the exact same second.
Instead, you are looking at a system-wide electrical or feedback failure. All your ignition coils share a common power source, a common ground network, and feed back into the same engine computer (PCM/ECU).
The main culprits for this issue include:
Blown or Failing Ignition Fuse or Relay
All ignition coils receive 12V power from a shared circuit. If the ignition fuse is blown or the ignition relay is failing/corroded, power to all coils will drop intermittently or entirely.
  • The Fix: Check your vehicle’s fuse box for any blown fuses or bad relays labeled IGN, INJ, or COIL.
Failed Main Engine Ground
Ignition coils require a strong, clean electrical ground to fire correctly and send feedback to the computer. If the main engine ground strap (the thick wire connecting your engine block to the car’s frame/battery) is loose, rusted, or snapped, the electrical circuit for all coils collapses.
  • The Fix: Locate the engine ground straps, clean any corrosion off the metal contact points, and tighten the bolts.
A Main Wiring Harness Short or Corrosion
The wires for all the coils bundle together into a single master harness before routing to the PCM.
  • If a single wire within that harness rubs against the engine block and shorts to ground, it can disrupt the voltage signals across the entire circuit.
  • Check the master electrical connector where the engine harness plugs into the main vehicle firewall for water intrusion or bent pins.
Damaged PCM / ECM (Rare)
The Powertrain Control Module uses internal electronic switches ("drivers") to ground and fire each coil. While rare, a massive voltage spike (from jump-starting backwards or a severe short circuit) can damage the main ignition control chip inside the PCM, causing it to lose control of all cylinders at once"
How's your grounding spots looking? I had a similar issue a while ago, the stud holding my main grounding wire to the fender broke. It would run extremely rough for 30 odd seconds then die and flood the cylinders.
Otherwise I think you'll just have to start tracing the wires and see if you can't find some damage to them.
Ground looked okay. I pulled it cleaned it and put it back on, but it didn’t help.
Do you think it would be able to start up for a moment before it died if there was a short in the wires somewhere?
What you had described about the engine start and immediate dying sounded like what I had experienced with my '95 Grand Jeep Cherokee w/V8 .
Out of the blue while on the way home, stopped to pick up some groceries and the first stop @ a stop sign to exit parking lot, engine died. Started right away, died right away. To keep engine running from another start, had to feather throttle to give it a little more gas. Made it home by repeating this procedure @ every stop. Stopped by local repair shop the next day and mechanic showed me that a can of throttle body cleaner sprayed into the TB magically solved the problem. Worth a try IMHO. Also check resistance to TB motor. Should show 0.3 to 100 ohms @ 68 degrees F if in good operating condition. Hope this helps.
worriedgild
