Replaced the OEM battery on my '18 SR5. Wouldn't crank yesterday. Charged all night, fired it up and drove to town and had it replaced. Die Hard Platinum AGM 710 CCA/885 CA at Carquest. Then I gave it a much needed bath at the coin op.
Caught up on a few maintenance items. Engine oil and filter, radiator drain and fill, Power Steering reservoir drain and fill and transmission drain and fill. After recovering from that, 4 new tires - Toyo Open Country AT III.
tailpipe fell off this morning. tried to inspect and see if I could somehow keep it up there. broke at the flange. couldn't remove it, exhaust going straight up and around wiring. got underneath and started inspecting. after about 2 minutes of a constant shower of rust flakes falling on my face I swore a few times , drove it to toyota and left it there. original exhuast, 14 years old, 180k miles, acceptable life span
Pulled to a stop down our driveway in the 2014 SR5 and could hear metal on metal grind from rear brakes. Pulled the right rear and the outer pad was just worn down to the metal, inner pad had like 1/4” left. Left rear both pads were the same at 1/4”. Had replaced stuck left rear caliper 75K miles ago. Time to replace right rear caliper, pads and rotors. Had new pad and slapped them in on right rear so car could be used while waiting for the other parts to arrive. Still have my wife’s 2023 ORP and my ‘99 K2500 Suburban to drive. I’ll do some fishing while waiting for parts and the weather is still good here in Montana.
Slapped together a short video of me installing a ValvoMax oil plug and "attempting" to use a MotiveX filter wrench and drain. The wrench worked great on the filter, but the drain plug was not coming out.. I had to remove the filter still full of oil. I'lll be purchasing the oem metal oil filter soon.
Today, for my 4Runner's 100,000 mi anniversary I decided to upgrade her sound and bought some Kicker KS 6x9 component speakers for her front doors and a Kicker Key amp to power it all. They also sell a complete 8-speaker kit, so before I bought anything, I listened to my current factory stereo to see how much the rear speakers contributed to the sound. Honestly, it was hard to hear any difference with the rears balanced to the front 100% vs normal 50/50 panning. Maybe 5%? I understand all the rears are running at 8ohms with a crossover and it just kills their volume and sound quality. A quick AI search confirmed my suspicions - and the fact that I don't have party mode - so I only bought the front pair.
For now, I'm holding off on speakers for the rear because the current ones probably work well enough for the quantity of sound they contribute. We'll see how the Key amp DSP changes things once the install is complete. I understand it can actually fix the volume imbalance and restore the crossover frequencies in the rear speakers. If it can do that, I will be very impressed. I'd love to have better sound out of the tailgate.
I replaced my battery preemptively before winter, they tend to last me about 3 years in the Texas heat. Yesterday I changed out the rotors and brake pads in an attempt to rule out causes of vibrations (they get worse when hitting the brakes. It did not stop it). Today I did an oil and filter change along with changing out the Frantz bypass filter. I changed the air filter too. Friday I will get new tires (Yokohama Geolander AT4) and then will get an alignment.
Stopped at the tire shop for rotation/balance. Someone there was having a bad day.. I ended up having three wheel studs to replace this week. One sheared at the shop, other two were cross threaded or way over torqued, discovered while going in to replace the first one. Another day, another lesson!
Did some fiddling with my new dash camera set up with front and rear cameras. There are no markings on the rear camera to give a clue as to which side is up, , instructions simply said "mount the rear camera", and it was displaying upside down. So I corrected the issue and now the view is normal.
I never really cared for a dash camera. but man the way I see these e scooters riding terribly unsafe Ive thought more about it. cars are almost always at fault unless they can prove otherwise and an e scooter has zero chance vs a 5000lb vehicle. I was going 10kmh, not miles, km through a parking lot and some 9 year old was cutting through the cars on his scooter. I saw him and stopped but these kids really dont understand safe riding and what really happens to their bodies in a pedestrian vs. vehicle. at least he had a helmat
Hooked up my old utility trailer, drove 2.5 hours and picked up a new dishwasher that I ordered from Lowe's yesterday. Had lunch, drove home. Traveled at 70 mph both ways. I got 18.9 mpg. Normally, sans trailer and traveling the speed limit of 80 mph, I get 20.5.
Even though I live in a very rural area, I've had several close calls by people driving distracted, drunk or in a rage. Severe tailgating has become the norm. Running a red light or 4-way stop seems to be a local sport. If hit, I want visible proof of someone else's actions causing it. Not the falsehood of someone in authority covering theirs or a loved one's ass.
Ive never understood running stop signs or red lights. I do not understand. seriously injuring someone by that type of negligence has state/province driving and insurance issues/charges that will follow you for years if not forever. you then have the legal issues that come with it in civil matters. Ive seen enough of what happens to people and children in car accidents to just always drive carefully, even if you are 0% fault, your life is likely going to suck for a while if you're the driver. In canada the penalties are weak, people dont care because the fines are small
H.Sikina
