Sherpa Equipment CO. - The Sherpa Edge (What makes us the best)
SherpaEquipmentCo
official vendor
The Sherpa Edge
With the market more saturated than ever, it’s important to understand what product offerings are available to you. Not all rack systems are created equal. At Sherpa Equipment Co. we believe in providing our customers with unmatched quality and attention to detail. We have spent years refining the modular aluminum rack system so that you can Adventure with Confidence.
STRONGER ALLOYS
All Sherpa rack systems make use of 6061 aluminum, over the competition’s 5052, for its superior strength and durability.
THICKER MATERIALS
The materials used in our racks are 33% thicker in the side plates, mounts and wind deflectors.
HANDLES & TIEDOWNS
Our modular rack systems feature integrated handles and tie downs built right into the side plate profile.
STAINLESS HARDWARE
Rust is a thing of the past. All of our products use stainless steel hardware so you don’t have to worry.
RUBBER ROOF SEALS
We don’t believe in large globs of silicone, so our products employ rubber seals and washers to ensure your vehicle stays dry.
DIRECT MOUNTING
Our mounts distribute large loads efficiently by keeping the primary load path as short as possible, bolting directly to the crossbar.
CROSSBAR SLOTS
Our side profile allows for more adjustability with larger slots and less fixed points when compared to the competition.​
ADJUSTABLE MOUNTING
Over the years we have learned that no two vehicle roofs are perfect and we design our products to accommodate that so you can avoid the frustration.
RETAINS XM ANTENNA
While many racks on the market require you to replace your XM antenna or alter the crossbar configuration, our rack systems accommodate and protect it. This provides you with more mounting space and prevents the need for vehicle modification. (Except the Storm Rack on some F-150 Platforms)
2 INCH MAX HEIGHT
We believe in keeping loads as low as possible while maintaining adequate distance from vehicle surfaces. This reduces your center of gravity as much as possible without touching your paint when loaded down.
TIGHT FIT SIDEPLATES
Along with our low profile we match our side plates to the curve of the vehicle. For most vehicles the side plates ride within ¼” of the vehicle's curve. This allows for clearance when loaded while maintaining a nice appearance.
FLAT TOP MOUNTING
Our racks have a truly flat top so that you can maximize crossbar contact and distribute loads evenly and efficiently.​
MADE IN AMERICA
All of our products support economies within 500 miles of our shop in Colorado. We believe in the talent and skill of American workers and we are dedicated to supporting fellow small business owners whenever possible.
WARRANTIES
We proudly stand behind our products with our warranty program. Our products are some of the toughest on the market, but some adventures get crazier than others. Rest assured we will be there to get you back in action as quickly as possible.
CUSTOMER SUPPORT
Taking care of our customers has been at the forefront of our business since day one. When we started, off road shops were notorious for terrible communication. We go the extra mile so that our customers can adventure with confidence.​
If you have any questions, do not hesitate to call or email us.​
