So I put a new head unit (Jensen VX3022) in my 2000 limited, I used a metra harness (Metra Part # 70-1761 | Toyota wire harness | Metra Online) to make the connections to the factory harness.
Per the harness the blue wire controls the power antenna, check all connections and continuity...all good.
Here is the weird part, when you turn the car on the power antenna goes up...even if the head unit is off...turn the head unit off and antenna does not go down...turn the car off and it goes down after about 5-7 seconds.
The factory radio ran the antenna just fine. All other function of the new head unit are spot on. I did remove the factory amp during the install.
Anyone else run into this issue? Any idea what might cause this?
Thanks.
Thanks.
