03-05 custom halo
Ashtonguyton
I'm wanting to do a halo mod for my 03 reflector headlights. Does anyone know what mm size ring I would need for the high beams and for the Low means. It's hard to find big enough rings for the low beam might just do the high beam and fog lights. Any help is greatly appreciated on size of high, low, and, and fog lights. I don't want to bake my headlights just to get a good measurement and hoping someone has already measured them or has some open lights around.
talk to [MENTION=55855]zopperman[/MENTION] or [MENTION=93434]gshadow325[/MENTION]
It won't really work unless you throw a projector in there. The bezels are "C" shaped so you can't put a halo on them.
You can buy my aftermarket halo projector lights :Becky:
Well what about some led strips where the LEDs are close together and I form them into a C shape.
Uhh that could maybe work if you could get really flexible ones. The bezel surface is flat and a c shaped halo would work. But you can't cut the halo.
I measured the bezels somewhere... Check my headlight build thread
delislerebecca
