TeryT said:OK, once & for all, does the 03 have the tire pressure monitor? I've never seen mine go on, if it does - but my dealer insists (over the phone) that it has this.
Would I, like, have to air it up again?Thai said:Why don't you try to deflate one of your tires to check it's functionality?? Doesn't the Owner's Manual have a way to check (or reset) the system?? It probably involves pressing and holding the button.
There is no "reset" button. Turn your ignition on and check the gauge cluster for the warning light. If you don't know what it looks like and your owner's manual doesn't tell you then guess what? Also, the rubber valve stems are an even easier way to check: If you got them then you haven't got TPMS.bulldog-yota said:My 03 does not have the sensor... Besides all the warning lights are supposed to come on once you just turn on the ignition, see if it is there. It should also be mentioned in your owner's manual.
No, just deflate all the others to match ...TeryT said:Would I, like, have to air it up again?
And plus mid-year 03 they added the class 4 hitch to the V8 & increased the towing capacity.EDGE said:My 03 does not have it, not listed in the 03 brochure or the owners manual which I read cover to cover.
They added it into the 04 along with the back up camera on the Nav.
The only real change to the 03 mid year was the appearance package on the SR5 & Sport that did away with the unpainted plastic cladding.
JThree4Runner said:Here's a question -
I've got an '04 SR5 and I'm planning to buy someone's Sport Edition wheels (same model year). Will the sensors still function properly on my truck? You know, different sensors on different wheels being placed on a "new" truck.
Any ideas?
Thx gang!
Any ideas?
Thx gang!
