03 have Tire Pressure Sensors
TeryT
OK, once & for all, does the 03 have the tire pressure monitor? I've never seen mine go on, if it does - but my dealer insists (over the phone) that it has this.
Why don't you try to deflate one of your tires to check it's functionality?? Doesn't the Owner's Manual have a way to check (or reset) the system?? It probably involves pressing and holding the button.
Same question...I can't find it anywhere in the manual.
CV
My 03 does not have the sensor. I think it was only introduced with the 04s. Mine was build in Oct 02, so the late 03s might have it. But as a general rule most 03s doesn't have it.
SImilar to the transmission dipstick the 03s have them, but not the 04s.
Besides all the warning lights are supposed to come on once you just turn on the ignition, see if it is there. It should also be mentioned in your owner's manual.
My Sport, built in May 03, does not have it. Mine has rubber/plastic valve stem caps/covers. The T4Rs that I have seen with the pressure sensors have metal valve stem caps. Just an observation.
03's don't have it. Mine has a July 03 build date and it does not have it.
04's got "always-on" gauge lights and tire pressure sensors while SR5's lost the telescoping steering wheel.
Would I, like, have to air it up again?
bulldog-yota said:
My 03 does not have the sensor... Besides all the warning lights are supposed to come on once you just turn on the ignition, see if it is there. It should also be mentioned in your owner's manual.
There is no "reset" button. Turn your ignition on and check the gauge cluster for the warning light. If you don't know what it looks like and your owner's manual doesn't tell you then guess what? Also, the rubber valve stems are an even easier way to check: If you got them then you haven't got TPMS.
My 03 does not have it, not listed in the 03 brochure or the owners manual which I read cover to cover.
They added it into the 04 along with the back up camera on the Nav.
The only real change to the 03 mid year was the appearance package on the SR5 & Sport that did away with the unpainted plastic cladding.
And plus mid-year 03 they added the class 4 hitch to the V8 & increased the towing capacity.
Here's a question -
I've got an '04 SR5 and I'm planning to buy someone's Sport Edition wheels (same model year). Will the sensors still function properly on my truck? You know, different sensors on different wheels being placed on a "new" truck.
Any ideas?
Thx gang!
JThree4Runner said:
Here's a question -
Any ideas?
Thx gang!
They should work fine because the sensor is in the rim. As long as the other 4Runner has the tpms, I don't think it should matter because every 4Runner has the same sensor. Don't hold me to this though because I don't have the tpms so I don't know specifically how it works.
JThree4Runner said:
Here's a question -
Any ideas?
Thx gang!
I'm pretty sure the tire pressure sensor in each wheel is registered to the specific car. The new wheels will have to be "programmed" to your car.
Think about it, if every 4Runner used the same sensors, then every time you drove by another car with sensors and different tire pressures, your light would go off.
