'04 Driver's Side Outer Door Weather Strip?
Okie
Has anyone ever replaced the upper outer door window weather strip? Is it just a matter of removing the one screw located on the upper end and just pulling or is there more to it? Tried search with no luck.
yes, its pretty easy just, remove the screw and the mirror, which is held on by 3 10mm nuts. then with the window rolled down just pull it off. may not neccessarly have to remove the mirror, unless ur comfy with doing so, it just makes the project 100% easier. prob done a million belt molding removals at my bodyshop, nothing to it.
Thanks for the info - I just removed the back small screw and slid the moulding slightly from behind the mirror then pulled upward. Replaced it yesterday.
chasebradshaw
