04 Interior and Exterior Mods
rossagge
Even though it's sold, I thought I'd show the aesthetic modifications I did to my Gen4 T4R before I sold it. I got bored with the way my interior looked, so I decided to change it up a bit, twice! The first change was painting the silver trim pieces metallic blue. If I had the 4Runskie to do over again, I woulda went with a metallic gray instead. The second change was vinyl wrapping those pieces in 3M 1080 Black brushed steel. I also cleaned up the headlights with 2000-3000 grit sand paper and buffed them out with polishing compound and sealed them. The exterior trim, badges and wheels were Plastidipped using Anthracite and Matte Black finishes.
This is a thread with pics of it all done at once. I decided not to make separate thread and to just show it all here.
All modifications were during my ownership before I decided to sell it to a buddy of mine whom I know will keep it running for years to come. It's creeping up on 200k and due for a timing belt change and water pump. It previously had the electronic shift actuator replaced shortly after I bought it. Other than that, it's G2G!
Below are some pics of what I did to it. The interior was a "dual" process so to speak. Underneath all that trim it was pretty filthy. So as I took it apart, scrubbed and cleaned not just the trim pieces, but also what hidden under those parts. in all the nooks and crannies. I let a family member keep (store) it while I was deployed and well, it was utilized and smoked in heavily! Needless to say it needed a lot of work to get the coffee stains, ashes, fast food gunk and the smoke smell out permanently. A major cleaning process (which took days to weeks with continuous treatments) under the dash, in the vents tunnels, under the center console, seats, rear cargo compartment, carpets and headliner neutralized any smell. I used some Simple Green, apples, coffee grounds, newspapers, bowls of apple cider vinegar all in combination over time to eliminate the funk and smoke smell. With my buddy's help, the smell has been neutralized!
I just wanted to write up this thread to help out those who are looking for ideas to use or improve on and that wanted to do some inexpensive and fairly easy DIY interior and exterior trim modifications to their Gen4 Runner.
If you have any questions or comments, please feel free to ask or let me know. Thanks All!
Before
Before
After
After
In the sunlight
Grille removed for plastidipping.
Grilled plastidipped in Anthracite
Grille badging getting sprayed Matte Black Plastidip
rossagge-albums-trim+work-picture26225-grille-badging-getting-sprayed-matte-black-plastidip.jpg
First & second coat of Antharacite on front bumper trim
More coats of Anthracite
rossagge-albums-trim+work-picture26227-front-bumper-trim-sprayed-anthracite-plastidip.jpg
Front bumper trim plasitdipped in Anthracite
Wheels gettin some!
Rear bumper trim plastidipped Anthracite
Rear bumper trim and badging
rossagge-albums-trim+work-picture26233-rear-bumper-trim-anthracite-toyo-matte-blk-plastidip.jpg
Exterior completed...without center caps installed (forgot to put them on for pic)
Grille and badging reinstalled
Not sure why I never took pics of it completed and clean, but here are a couple of it out on the trail.
Never did the roof rails. Planned on it, but sold it before I could plastidip those Anthracite. My buddy might end up doing that to complete the look.
Interior getting taken apart.
Dash trim getting prepped for paint
Instr cluster surround, shift trim surround, shifter trim, lower storage tray and HVAC controls coming out.
rossagge-albums-trim+work-picture26245-instr-cluster-surround-shift-trim-hvac-controls-coming-out.jpg
Dash trim sanded down and masked off ready for primer.
rossagge-albums-trim+work-picture26250-center-console-dash-trim-piece-sanded-primed.jpg
Instr cluster trim piece masked off, sanded and ready for primer
rossagge-albums-trim+work-picture26252-instr-cluster-trim-piece-masked-off-sanded-ready-primer.jpg
Center dash trim, shifter bezel and shifter trim piece sanded and ready for primer
rossagge-albums-trim+work-picture26251-center-dash-trim-shifter-bezel-shifter-trim-piece-sanded-ready-primer.jpg
Primed and ready
Insr cluster surround primed
Shifter surround and shift knob trim primed
Ooops! Got the dash trim piece painted with second coat and got heat gun to close! Arggh! Had to re-sand and touch up.
rossagge-albums-trim+work-picture26256-ooops-got-dash-trim-piece-painted-second-coat-got-heat-gun-close-arggh-had-re-sand-touch-up.jpg
Instr cluster surround coming along nicely. Thought this would be the most difficult piece. Just took a while to mask off correctly.
rossagge-albums-trim+work-picture26257-instr-cluster-surround-coming-along-nicely-thought-would-most-difficult-piece-just-took-while-mask-off-correctly.jpg
Installed
Center dash trim installed
Shifter bezel/trim installed
Shift knob trim installed back on knob and screwed back on
rossagge-albums-trim+work-picture26261-shift-knob-trim-installed-back-knob-screwed-back.jpg
I also painted the lower trim piece on the center console.
rossagge-albums-trim+work-picture26262-i-also-painted-lower-trim-piece-center-console.jpg
My second go at the interior. This time with 3M 1080 Black Brushed Steel vinyl wrap
This one was a bit tough to wrap...for me.
That's all Folks!
How did you like the anthracite plastidip? Just bought some for my wheels and am still unsure about it, every pic I see it looks different
I was going to go that route and realized the same thing, I didnt like the look. Several years ago I decided to plasti dip black and then paint over the dip, holds up awesome. here are the 2 different colors I have done.
I feel the paint over the dip actually protects better than just dip, which makes it all last longer.
http://www.toyota-4runner.org/1709235-post12809.html
http://www.toyota-4runner.org/4th-gen-t4rs/99069-weekend-mods-plasti-dip-spray-paint.html
I like it. I think it's a nice change to the matte black always seen. I do like some vehs with the matte black look, but I choice to go this route for a change. It's metallic, so it will have a diff look with certain colors I feel. Try it out and see. If you don't like it, you can just peel it off!
Cool. How long have you had the painted over plastidip wheels? It would seem the paint would eventually start to separate from the plastidip. Is it permanent? How easy is it to remove from the wheels if not and is the paint sealed? Curious to hear how they held up. Thanks.
First time i dipped and painted it help up perfectly for 2 years and 26k, I removed the paint and dip for new tires and wanted to go another color. Over the 2 years it looked exactly like it did day one. No probs or separation. Wheels looked like they came that way.
The recent, bronze color has been on about 2 weeks or so, and so far still looks brand new.
Not permanent by any means, however I think with paint over the dip its much stronger than just dip. When I removed the first time, i tried a car wash pressure washer and it did ok. I then used a gas pressure washer to remove it completely, stuff just blew right off, had a mess with the paint flakes but not a problem.
Hope this helps
