04 po40
manp0899
I have been trolling through the forums about this for sometime but I still wanted to make a post to get some fresh ideas of how to proceed to get this issue resolved. I have a 04 4r and I have been having this issue for about a year now. Initially I have been having my check engine light come on very rarely probably once a month, of which I took to my mechanic or Autozone and get it erased. As it started getting more frequent approx every 2 weeks I just purchased my own. Fast forward to now I get it almost daily where I reset it myself usually at red lights while I am driving. The most annoying part about it is not the check engine light, it is the vsc being disabled. also in the beginning it was just bank 1 that was out now its both bank 1 and 2, prob reason why its more frequent.
I am looking now to correct the problem and I have been hearing of several ideas that can help resolve the problem.
First approach checking the gas cap and make sure its tight and there is no airflow. Possibly get a ring around the cap making sure there is no air leakage.
Second is the seafoam additive. Put it in through the vacuum line and in the gas tank. Basically try to clean out all the carbon deposits in the car.
Third is changing o2 sensors. This is something that I will probably do. I have read that the post cat o2 sensors can go bad and give false po40 codes. Now should I go ahead and change all the o2 sensors? because the last time I replaced an o2 sensor had to be around 80k miles ago at least, and that was only one sensor.
Lastly change the cat, Magnaflow:
Magnaflow 15781 Stainless Steel 2.5" Single Cat-Back Exhaust System : Amazon.com : Automotive
Question with this do I still need to replace my o2 sensors anyway or will the new cat need different sensors or come with sensors?
Any thoughts on how I should proceed?
I have been driving with this issue for awhile so I am not aware of any acute changes since its saying both cat banks are out now. I do not believe it drives or idles differently but the exhaust does smell more like methane or like there is more fuel being mixed into it. One thing I did notice though is that my gas mileage has suffered.
Another question is that if I do change the cat do I have to replace to o2 sensors or does the cat back come with new o2 sensors?
