04 with FJ Springs and 5100s
asnatlas
I picked up some FJ springs and 5100s. I forgot to take measurements before starting but seems like most 4th gens are around 34.5" on avg with stock suspension. I have the 5100s set to 3rd groove which is 1.75". When I took a measurement the passenger fender is at like 38". That is with no spacers installed. That just seems too high to me. Anyone have any ideas ? I don't see how I messed anything up. Even if I went to the 2nd groove (.85") on the 5100s that would still put me just over 37" which is 2.5in. I was thinking I read if you wanted a 2.5" lift you would set your 5100s to the 3rd groove. I seem to have gotten like 3.5" I was told that the FJ springs have less then 100miles on them but I can't see that adding that much to the total lift until they "break in"...
Here are some pics...
Passenger side at 38"
Driver side suspension #1
Driver side suspension #2
What is the stock height of the 4th gens ?? I see people are getting about a 2in lift with the 5100s on FJ springs on a V8. If that is the case then I would have been around 33" before the new suspension. Also the .5" diff from the driver to pass is killing me. Is there anything I can do other then getting a spacer ??
Something is not adding up. I found a post from MSBX4RUNNER with the following details :
2005 SportEdition
2wd
v8
FJ Coils off a 2007 FJ with 26K miles on them
Bilstein5100s set at 0.85"
Before measurements:
Front Driver 33 7/8" Front Passenger 33 3/4"
Rear Driver 35 1/4" Rear Passenger 35 7/8"
After measurements:
Front Driver 35 7/8" Front Passenger 35 7/8"
Rear Driver 36 3/8" Rear Passenger 37 1/8"
I ended up gaining a little over 2" in the front and 1.125-1.253" in the rear
I have a V8 and I have the 5100s set to the 3rd groove (1.75"). MSBX4RUNNER only has his set to the 2nd (.85") and I have less front lift then he got...
It's been pointed out the v6 is lighter than the v8, thus the FJ springs provide more lift on the v6 than they do on the v8 (about 1" vs. .5" with standard shocks). I believe the 5100's exaggerate this even more. A friend put 5100's and FJ springs on his v8 4x4, set on .85". He got just over 1.5" lift. It's hard to guess what you'll get, but the numbers posted don't make sense.
I know that a V6 will gain more lift then a V8. I was not aware that a AWD would gain less lift then a non AWD.
Even at that it seems like I only gained about ~1" with the 3rd groove (1.75") on the 5100s...
Damn I wish I would have taken measurements before I started :(
ARK_SWAMP_RIDER, would you be able to get a total measurement from your friend on where his front fenders sits ??
A 2wd is lighter in the front end, so the end result is greater. His 4runner sits at the exact same height as mine (I have 1.5" lift and slightly taller tires). My front measures ~36" fender to ground best I can remember. I can measure tomorrow for sure.
Next Thursday I'll have FJ springs from a 4wd installed along with FJ Tokico shocks - all parts are supposed to only have 50 miles on them, and they looked quite clean when they arrived. Bought off CL from a guy in CA who got tired of them lying around after a 6" lift in 07.
I'll take pics and measurements to let you know what I get as far as lift (even though I am not using 5100's). I have an 07 SR5 4wd V6 at 90k miles, without the xreas.
I just took the 4runner around the block and recorded another measurement. 35.5 (driver) and 36.25 (pass)... So if I was around 33ish to start, that is about 2.5" to 3.25" lift... Knowing that I have .75" diff from side to side is killing me... Is there anything I can do other then get a spacer ?? I need to get it in and have the alignment checked. The above measurements are with the stock 265/65/17s. I have a set of 265/70/17s Goodyear Duratrac's to put on which will add about .5" as well.
Since the pass side is about 3/4" higher then the driver. Would I be able to use one 1/4" Front Top Plate Spacer which adds approximately 1/2" lift from Toytec ?? They have listed on the page "Great for correction of drivers side ride height." Any long term harm in running a 1/4" spacer only on one side of the vehicle ?? Is there anything I can check / do to "adjust" the lift between the driver and pass side front ?? I understand they will not be equal but 3/4" seems a bit much to me.
It seems that the V8 4WD gains about .5" lift in the rear with the FJ springs. Would the new 5100s affect the rear lift in any way ??
I was debating on adding a Daystar KT09107BK Comfort Ride 1.5" Lift Rear Coil Spring Spacer Kit to get a total lift in the rear of about 2" (1.5" +.5"). I see that Toytec has a set of Rear 1.5" lift Black Spacers Poly for FJ/4Runner which are about $50.00 more. Any reason in paying more for the Toytec spacer over the Daystar ?? I understand you get what you pay for but this is just a polyurethane spacer.
It just came to me... If I have both 5100s set to the 3rd groove (1.75") and I am about 3/4" higher on the pass side, I could set that corner to the 2nd groove (0.85") which should make the driver side about ~1/4" higher ??
Would that be doable without any neg affects ?? Would the shocks be that much different in response if they were set on a diff ride height groove ??
Well after a little driving and an alignment I seem to be at the following measurements:
Driver Front - 36"
Pass Front - 36.5"
Rear - 38"
workingwheelswnc
