You had this option on yours correct?
Was it worth it? Do you have any pictures of the switch, just so I know what I am looking for.
Thanks again for all the help and responses, I really appreciate it!!
The switch is located on the center console between the heated seat switches (Four main switches closest to the glove box/arm rest).
My 05 V8 Limited (Which was a GREAT vehicle) was just totaled (No one was hurt). I special ordered it for the auto-leveling rear air suspension and color. I needed it for towing. I can tell you that in the, almost 6 years, I put a lot of weight and miles on that system and it never skipped a beat. There is a 4" difference in height between low to high. I found it very useful for off-roading, deep water, towing, carrying cargo, loading and washing. Sometimes I would be towing at near its max rating loaded with people, equip, supplies, bikes, towing a camper and the vehicle was ALWAYS level and in total control. Sometimes I would have to use off-road approaches with the trailer and I would use the system to adjust the approach/departure angles of the trailer and the tow hitch/vehicle to get over ruts and obstacles. By lowering the system you would raise the back of the trailer. I also found that the handling and ride is smoother with air bags instead of springs, especially when the vehicle was empty.
I also use a motorcycle carrier that utilizes the tow hitch. I lower the vehicle, role up the bike with a ramp from the side. As soon as you start the vehicle the system levels off. My bike weighs just over 500lbs (Sport bike). It’s amazing how the vehicle rides with over 600lbs hanging off the back of the vehicle.
Here's the problem, I was spoiled with this system and must have it in my new truck and it is no longer available in the 5th gen (And the V8). This is why I why just special ordered a GX. It turns out the GX has this system combined with KDSS (Optional on the Trail) and AVS (Adaptive variable suspension). It should be very interesting towing with this set-up.
Koz
