'06 V8 4Runner Shimmy & Shake
shoot4boge
My '06 4Runner is shaking and shimming like you wouldn't believe. After having it to the Toyota dealer multiple times I finally broke down and got new tires as this is what all I spoke to said I needed to do. Well, things are no better! Please Help Me! the dealer did note that my shocks are leaking and so is one of my struts! I only have 45K on it! Do you think this is the problem? I can't stand to drive it anymore :(
Not all new tires get balanced right the first time. Good read here.
Play with the tire pressure a bit. Try as low as 30psi on a cold tire and as high as the max tire sidewall pressure. If the vibration ceases or changes dramatically at a specific pressure I'd say the shock(s) may have leaked enough to affect the shocks' performance.
I am making the assumption the rims were spun and inspected for runout/bends/imperfections.
I'd check this adjustment too.
My final thought is wheel torque. The rims are hubcentric and need to be torqued evenly and progressively at install to ensure they are seated properly.
Just my 2cents
:cheers:
Rialm
