07 Gas mileage
iRCaDiKz
When we bought our 07 4runner the gas was ok, first and 2nd full tank i was getting 17-18.9 city now it has 900 miles i'm only getting 12-13.9 city why is it like that?
im using regular gas..
If this from the onboard trip computer? If so, try resetting it. I don't even use it as it isn't very accurate.
:iagree: Ignore the trip computer on the dash - it's not right. Record your mileage with the trip odometer, and then divide by the amount of fuel you put in the tank.
You don't mention whether you've got a V6 or V8 - the V8 will do slightly worse than the V6. I'm getting about 15.5 city with the V8. EPA perfect world estimate is 16 city, so I'm right there.
it's v6 4wd
I reset the trip computer every 3-4 tankfuls and take 7% off the reading at each fill-up.
It then seems to compare accurately with the hand calculated mileage figures. In this way it is useful because it is repeatedly 7%, or so, off. So normalize the reading and you should be pretty close to the real number every time.
I know its not the right thing you want to hear,but just give it time to break in . don't worry about the in dash comp. ( although I find mine pretty accurate ).
Way to soon to worry , break it in first. The comps are still learning.
This is correct and has been verified by myself & others.
Also, many 4R odometers are under-reporting by around 3%. This was the case with mine, and I checked it with a GPS & mile markers a few times.
When my tachometer (electronics) went out this spring (around 55k miles), they replaced the entire instument cluster. After that, my odometer seems to under-report now only about 1.5%, which is negligable. (But now I notice my speedometer over-reports about 2 MPH going at 60!) Perhaps new models have more accurate ones.
alexhales578us
