07' V8. Chain or timing belt?
And it is a interference engine, meaning you don't want to go much past the 90,000 miles before you change it.
kn38ms said:
What does the 4.7L have?
What is the required replacement mileage?
4.7 has a belt, 90k miles or 9years is the prescribed interval. Replacing the water pump, idler pulleys and tensioner is always a good idea when changing the timing belt. Replacing the belt is a labor intense job. The aforementioned parts all require disassembly/reassembly on a very similar level to the belt change. It's one of those "if your in there you mine as well...." deals.
Check out these two links.
http://smg.toyotapartsandservice.com/guides.php?xv=1&xy=2007&xint_id=24&v=1&y=2007&int_id=18
http://smg.toyotapartsandservice.com/index.php
:cheers:
Edit:John & Peter are fast! I started my answer, went for some coffee and then posted! They had it covered, I'm not attempting to be a post wh*** :D
Re: Re: 07' V8. Chain or timing belt?
That makes sense.
May as well have the valve shims checked and throw in some new plugs. ;):
