1/2 body lift
Coopsdaddy
Anybody running a toytec ultamite with a 1/2 bodylift.
I would like to lift it a little more but don't know if I need another 1 inch so I thought about going with a 1/2 inch.Im running 265/75/16
Hey coopsdaddy
Click on the link below my post here that says 3rd gen body lifts. That is my for sale page all about the lifts.
I can make any size you want.
Shootmymime has a good product. I have the 1" now and had the 1/2' in the past. I would personaly say go with the 1" for better under side clearence.
I have been going back and forth in my planning, 1/2" or 1" BL. I have the 1/2" now, NOT installed. I have stock suspension and I'm running 265/75/16 with no rubbing except maybe I have rubbed under extreme compression in the rear. I am doing a 3" SL, at least 1/2" BL, and maybe 255/85/16 in the future.
Coops, do you rub now? If you aren't rubbing, I'd say leave the BL out of the build. Are you planning on staying with that tire size as a maximum?
I'm looking to do the 1/23 as well. Wish I could find some pick of them installed. I keep finding the 1"+
I rub just a little but I mainly just want it to set a little higher without cranking the coils up.I will more than likely stick to 265 because I dont want to be short on power.
Yeah, I actually did a 3" body lift and now I want to lower my suspension to get better driveshaft angle and alignment.
I am currently sitting at about 6" of lift but it's actually higher than that since I have the '99 tall coils.
My plan is to install my toytec/bilstein coilovers and "suicide" upper arms as well as new OEM lower BJ.
At that point I will lower the front by about an inch. that should give me back the factory rake since my rear is only a 2.5" spacer on the coil.
I like the idea of the body lift since it has less effect on the CG than a suspension lift.
