1.25" vs 1.5" vs 2" Wheel Spacers
Kinda an old thread, but does anyone have pics of 33x12.5's with 1.25 wheel spacers?
Not sure if i need them. Got an 99 4runner, and 33x12.5s on 4th gen stock alloys i wana put on. Will i need em? Thanks for your input
I believe the 2" all pro spacers you are referring to are lug-centric, designed to work with older mini trucks and land cruisers. 3rd gen requires hub-centric spacers to work properly.
Just to add a little if I can. Most of the tire shops around here (CA) atleast in my area will not touch a vehicle with spacers.
Also if I understand correctly the rear wms is narrower than the front to make the overall steering radius of the vehicle tighter.
Ill input. Allpro 1.5":
2000 limited with stock 5spoke rims. 2.5 " lift in the front, no rubbing or trimming needed.
Can I ask what size tires you have on there? The 1.5" spacers look like plenty. Because the back is 1/2" more narrow, should I go with 1.25" fronts and 1.5" rear? Anyone? Thanks, new here.
Fact: The rear axle is ~1/2" narrower than the front track.
I can't find anywhere that says the rear track is 1/2" narrower than the front track. In fact the only place I can find so far says that the front and rear track are both 62".
I'm new here so I'm just trying to get my facts straight before I go getting spacers. Any help would be much appreciated. TY
EDIT: I also found both 62" here. :/ I'm confused
It's actually 5/8" narrower than the front. The best way to tell is to measure from WMS to WMS.
Id go with 1.5" rear and 1.25" front. I did and it looks perfect IMO
I read somewhere that the rear axle is slightly narrower to help the vehicle track better - it was designed and engineered that way from the factory for a reason.
If you put 1.25" all around you are maintaining what the designers intended. If you put wider spacers on the rear you are changing that aspect.
Anyway... this is my understanding.
The rear is a total of 1/2" narrower so you would want spacers that are each a 1/4" thicker. I would have done 1.5" in back and 1.25" in front if ST sold 1.5s.
I can't find anywhere that says the rear is 1/2" narrower. What year are you talking about?
Wheels spacers are next up on my list, but I can't decide on which size to get.
I know that Spidertrax only makes 1.25", but All-Pro makes all three sizes.
Right now I'm running 265/70/17 on Tundra rims. When I turn the wheels the tire is fairly close to my Limited flares.
Will any of these sizes cause rubbing?
Which of the three sizes will bring the tires closest to the Limited flares?
Pictures would also be helpful.
Thanks.
What year was your 4runner in this question??
3rd Gen's are all the same width. Doesn't matter on what year it is. I've measured the WMS and it's 5/8" narrower. No need to find a thread on it.
Michelin LTX m/s 265/75-16
i would go with 1.5" all around or 1.25 all around. make sure they are hub centric. (little lip around the inside edge. look at my pic again)
:fishing:
2" will RUB far worse when you turn the wheel.
2" will mean that the wheel will likely hit the fender at full compression - trust me!
1.25" with factory backspacing with 285x75x16 will mean that the wheel will hit the fender at full compression. I know!
slightly off topic question:
Spacers for a 2014 4runner are the same for 2001 correct?
I found some Spidertrax for sale locally.
Can anyone post more pics of 1.25 on a 3rd gen with limited flares? Just need to see an angle like this
What length should I get?
As we all know, 4Runner's have high roll over rates... My '97 has 3 inch Rough Country lift with offroading tires and stock wheels. I want to not only widen the stance to lower the roll over rate but i also like the way it looks. I'm aiming for 1.5 to 2 inches and hoping my lift stops rubbing and such
Yep. I just added some 1.25" spacers I had in my garage, and I am rubbing on the pnch weld now. I was not rubbing beforehand. And I am running 2" of lift up front.
I guess I need to start doing some cutting.... :shrug:
Save the cutting and do a BL:clap2:
EDIT: nevermind the BL, it won't help you in this case....just gave it a short thought after replying...
