1" Spacer Lift
Trdsupranick said:
put some pictures up if you guys dont mind of you lifts before and after and if you have install pictures that would be cool too!! that front 1inch lift from burtman i think is the most classy way of lifting the t4r
Check your private messages.
Although I like the larger lifts of the 2/1 or DS 2.5 , I do think the 1" leveling kit is a good way to go to get a little more clearance up front , level it out a bit , and prevent rubbing if you run the upsize tires ( which I do ) but have no rubbing issues. Even Steven said that his front is still a little nose down which is fine with me since I pull a trailer a lot . I dont know how the running boards or tube steps measure out front to back . I also think for a daily driver its the most practical way to go and gives just a slightly different look than the stock ones , especially if you have the 70 series tires on .
stc6306
