13 year old 4Runner...what maintenance should I be doing?
cullopj
Own a 2000 4Runner. SR5 4WD 3.4 V6 Auto. All stock. 94,000 miles. I don't know many specifics about the service history on my 4Runner, so what all maintenance should I be doing at this point. The guy who owned it before supposedly took good care of it. Only drove it around town to work and back. Had another vehicle so didn't put many miles in the 11 years he owned it. Since I've owned it (bought June 2011 with 74,000 miles), I've replaced the spark plugs and wires, brakes, accessory belts, starter, alternator as well as changing the oil every 3,000 miles. I know I'll replace the timing belt and water pump sometime soon. I've read about replacing the radiator or possibly just adding a external cooler due to "pink milkshake". Is it worth while to replace the radiator or to add the external cooler? I believe my whole suspension needs to be gone through as my rear-end sags as well. (any suggestions on what I should put on, or should I go back with stock) I also believe I might have some sort of exhaust leak (hopefully just a new muffler) as my 4Runner has more and more of a purr as time goes on. It can especially be heard when pulled up next to a wall on the passenger side. Any suggestions on a good exhaust to put on? Nothing too loud, but something that can be heard. Thinking about trd exhaust as I may put on supercharger in the near future.
Since my truck is all stock, I'm kind of new to putting mods on my vehicles. Would love to turn the 4Runner into a weekend getaway car to the Rockies.
I'm not scared by any of this, it's just part of owning a 13 year old vehicle that is still running on mostly stock parts.
Any suggestions on what all I should do to make sure my 4Runner is running in tip top shape and so I can prevent any future breakdowns? I would really like to get onto a tight schedule for maintenance with quality parts/fluids to make sure this truck will last me a LONG time...
I'd continue flushing fluids for starters. Brake and coolant systems, trans and t-case.
I wouldn't worry about replacing the rad if its cooling properly, but bypassing the internal trans cooler with an external one is a good idea.
If you don't know when they were replaced last, do the lower ball joints next. Use OEM. Then do something about the pink milkshake, replace the rad or just bypass it, whatever.
Once you've got those and any other urgent maintenance out of the way, get the maintenance list from the owners manual or FSM and start at the top. Work your way down. :)
