1989 Rear Window Help
Topless4R
After tearing apart my 4runner to find out why my rear window doesn't work, I have found the Window Relay to be faulty.
Instead of buying another or cutting it open and performing surgery on it, can I:
Completely bypass it? (don't care about wiper,defrost, etc.)
or
Use factory UP/DOWN switch in a new circuit that i create with an inline fuse?
-has anyone done this? Has 5 pins, read that 3 is negative, 2 is power to lowering window, 4 is power to raising window.
What are pins 1 and 5 for?
Where would I connect constant power?
Any help appreciated.
Yes I searched.
or
Yes I searched.
I can't tell you about the stock switch but I bypassed my stock system altogether. I used a reverse polarity switch and run a deadicatid fused wire from batt to switch and window motor. It has worked perfectly for 4 years.
Thanks for the help,
thinking about going with a 5 pin momentary switch. Would have to order online though.
Like this?
1. 12v
2. Motor UP
3. Ground
4. Motor Down
5. 12v
If you use two 5 pin relay switches it will work. However you will loose functionality of the rear wiper. You can't use a relay on the rear wiper or you will loose the "park" feature on the wiper.
I would suggest you go online to ebay and find a used relay. I had installed the 5 pin relays and found a 4runner relay on ebay for $50.00. Put everything back original and glad I did.
Found another Relay/Module today, swapped it in and nothing. :frusty:
It won't make any clicking noise.
Bad switch?
How would I wire the two 5 pin relays and a ON-OFF-ON switch?
Relay:
30-?
85-?
86-?
87-?
87a-?
Switch:
1-?
2-? (Middle pin)
3-?
Thanks for helping, last major thing I need to fix on my 4R. :frusty:
Using the 2 Relay method with 3 prong ON-OFF-ON switch:
relays:
30 motor
85 12v
86 switch
87 12v
87a ground
switch:
1- 86
2- Ground
3 -86
FAILED :gun4:
relays:
30 motor
85 ground
86 switch
87 12v
87a ground
switch:
1-86
2-12v
3-86
FAILED :gun4:
:wtf: Anybody see what I'm doing wrong here?
:whoo: Window Works! :whoo:
Pisa 8687 has a solution that works, bypassing stock circuit. (lose wiper,defrost, and key function...etc)
Need a DPDT ON-OFF-ON Momentary 6 Pin Switch ($5)
-I used : (Frys.com #7822479 Manufacturer: PHILMORE UPC #038975308463 Model #30-846)
Inline fuse holder (30a) / Wire
Pin Layout:
12
34
56
1- 12v (fused)
2- Ground
3- Motor
4- Motor
5- Splice into Pin #2
6- Splice into Pin #1
The switch fits perfectly into the stock window switch location.
Window will operate without the keys in the ignition.
Thanks again Chris
I bypassed everything in mine. Using dpdt momentary switches. No relays. Can't figure out the wiring with dpdt switches.
I think I used 20. Too small and too long. Window is slow. I may go back, but probably not. Top isn't going back on anytime soon.
Talyn
