1990 oil Pressure guage-what should it be at?
4runner316
Where should the oil pressure be on a 1990? I just bought her a few days ago and the needle was at about 1/2 way most of the time.. The last time I drove her it was sitting at the 1/4 mark at idle and then would go up just a tiny bit during acceleration. Should I be concerned about anything?
I had the same concern when I first started driving my t4r. Mine hangs out just below the first mark during idle and then goes up to around half during acceleration.
What I read from the Owner's Manual is that you are not in danger as long as the needle is above the first mark while the engine is being pulled on. These older engines are notorious for low pressure in their age, but they still run great... mine is up to 230k miles
This is what it says in my 1995 4Runner manual...
Mine sits in the first quarter at idle & ventures up to around halfway when revving (144,000 miles).
Ack, mine sits right at the "L" at idle and only goes up to where the needle is at in that picture when im driving (When the car is fully warmed up) Pressure is around the middle of the gauge when the engine/oil is colder.
Getting her checked out this week.
Does anyone know if a HG replacement involves moving or altering anything to do with the oil pressure gauge? Does a cable or anything need to be moved/removed during the process? The pressure was fine before the HG replacement.
Oil Pressure
Did you ever get your oil pressure checked out?
I have the exact same pressure in mine and need to know what to do.
Maybe a Toyota filter is in order?
A low reading at idle and low RPMs is normal and should increase and vary with higher RPMs. The wear of a high mileage engine would cause pressure to be a little lower.
mine sits exactly where it is in the picture when idling once warm. depending on the acceleration/RPMS - it will climb to the higher mark but usually sits close to the 1/4 mark in the middle.
as long as it has oil in it, it's fine. mine burns a little i guess ...
Yeah I believe it was down to the mechanic putting in a full synthetic 5W-30 oil. Its thinner than the conventional 10W-30 oil that Toyota suggests. I went back to 10W-30 Conventional and the pressure went back up to what those pictures indicate.
Its now running 10W-30 blended mix and its again dropped down a tad, but not as bad as it was with the full synthetic 5W-30.
glad I found this thread. my 95 has the same issue. I was about to bring her in to the shop, but I think I'll hold off now.
My 88 4Runner has the V6 and when it is cold it hovers around the half mark or a little higher, it will sit there like that until it warms up after about ten minutes. Once it warms up the needle hovers on the 1/4 mark at idle, and just north of the middle mark when above 1,800 rpm. I found out that if I run 10W-30 in the winter everything is fine until it warms up then the gauge barely moves above the 1/4 mark when going down the highway. I fixed that problem by running Toyota filters and I also run 10W-40 Conventional in the winter and HD 40 in the summer and it seems to like it, no excessive leaks or dry starts, but I am guessing that my engine has only around 200,000 miles on it, so try running a little thicker viscosity and see what happens. Also my uncle told me that running non-changing viscosity oil in the summer like HD-40 offers much better protection, because it contains more oil and less chemicals then changing viscosity oils. He seems to be right.
I'm in the same boat. I was given this 4Runner and put some work into it getting the AC fixed, leaky valve cover gasket, and lots of other odds and ends. I hadn't driven it in 2 months while all these things were being done to it. I drove it and noticed that gauge was on the low side. I can' remember what it was like when I got the car.
The engine has 216k on it. Purrs like a kitten. But that oil pressure gauge concerns me.
At first start up, the gauge performs as expected (in the middle as I drive it). As the engine gets warm, everything goes down to the 'L'.
Attached are two photos. One at idle. One while driving about 66mph at 2800RPM. The gauge is low.
It has enough oil in it.
The car will live down in HOT Cabo Mexico so I put in 10w-40 vs the recommended 10w-30. Was that a good idea?
2001ATL
