1997 SR5 4X4 5spd/Manual NEEDS REPAIR AUSTIN TX
the-magic-man
Hello all,
I have a 1997 SR5 4X4 with 5spd manual
Reason for selling is basically I don't want to keep putting money into it.
There are two known problems.
1. input shaft on the transmission is damaged. It will eat through the pilot bearing if not addressed in the future. New input shaft is $400.
2. The valve cover gasket is leaking.
Car is still drivable. It is having a new clutch put in as we speak.
The interior has some wear. I have detailed the car multiple times including cleaning the headliner and all the vents.
4x4 works. Tires are 80-100% tread. Spare is new. Oil changed every 5,000 miles.
Picture is old it is all I have ATM.
Work list
Engine:
-New timing belt, accessory belts and water pump
-New rear main seal
Cooling/Heating
-Koyo radiator
-New heater core
-New heater control valve
-New heater hoses
Transmission
-New clutch and throw out bearing
-New Pilot bearing
-New clutch fork
-New flywheel
Steering
-New Steering rack bushings
-New left tie rods
-New steering wheel
Suspension
-New Toyota front control arms upper and lower
-New upper and lower ball joints
-New Toyota rear upper control arms
-Rokman rear lower control arms
-Rokman adjustable pan hard bar
-OME 2" Sport Shocks and Springs
-New Toyota sway bars and end links Front and back
Misc
-Compustar alarm
-Sound system
-CBI Skid Plate
-Tundra brakes
-New battery
Parts that haven't been installed
-Savage offroad rocker panels
-CBI rear skid plate
Asking price is $5000
