1997 Toyota 4Runner SR5 - Rust Free, Ann Arbor, MI
skylinekin
I am looking to sell my 4runner as I no longer need it. This 4runner has served me well and I have spared no expense keeping it running in top shape. I am a 4runner enthusiast so all of the common problems have been addressed (this is my second 3rd gen, also currently own a 5th gen).
Asking Price: $7900
Basic Info:
Cool steel metalic exterior w/ gray interior
SR5 4WD w/ 3.4 V6
220,997 miles (as of today 6/4/16)
2 Toyota Keys w/ OEM Fobs
Owners Manuals
All original VIN tags intact, never been in an accident or had any paint work
Was an Arizona truck from 1997 - 2015, has only seen one mild Northern Kentucky winter during my ownership before moving to Michigan
Port/Factory Options:
VIP RS3000 Security System w/ Keyless Entry (Have 2 working fobs)
Rear Heater
Sport Seats
Carpet Mats
6 speaker cassette w/ CD player (works great)
Recent Maintenance History: (all OEM Toyota parts where applicable)
220,990 Oil Change w/ Mobil 1 K&N Filter
220,990 K&N Air Filter Cleaned/Oiled
220,990 Tires Rotated
220,990 Poly Front Sway Bar Endlink Bushings
220,450 Bilstein 5100 Front Shocks
220,450 OME 881 front springs, OME 890 rear springs
220,450 Weather Tech Floor Mats & Trunk Liner
216,588 A/C Idler Pulley
216,588 Oil change w/ Mobil 1/K&N Filter
214,986 Rear Hatch Wiring Repaired (Broken at joint)
213,215 Toyota Truestart Battery w/ new positive terminal & hold down
212,746 Front Lower Ball Joints Replaced (preventative, were not damaged)
212,746 Re-booted OEM Front CV Axles w/ new axle seals
212,746 FR & RR Diff, Transfer Case Fluid Change (Mobil 1)
212,078 Valve Cover Gaskets w/ cam plugs, half moon reseal, PCV valve & grommet, Intake Gaskets, TB Gasket
212,078 NGK Spark Plug Wires & OEM Plugs
212,078 Power Steering fluid flush w/ Mobil 1 ATF
205,000 New Bosch Starter
192,261 miles Timing Belt, Seals & Water Pump
Upgrades:
B&M External ATF Cooler w/ Radiator line looped
LT285/75/16 Goodyear Duratrac Tires
Bilstein 5100 Front Shocks w/ OME 881 Springs
Bilstein 5125 Rear Shocks w/ OME 890 Springs
Front Differential Drop Kit
Sonoran steel rear adjustable panhard rod
Whitson metalworks roof rack
Rocky Mountain super sliders
Addicted off-road Rear Bumper
Fixed Antenna Conversion (OEM Toyota Parts)
Plasti-dipped OEM Fender flares w/ 3D printed End Caps
99+ Headlight Conversion (OEM Glass)
Deckplate Mod
Hi-Lift with custom Mount in hatch
Leather Steering Wheel Cover
k&n drop in filter
Bolt on Wheel Spacers
Item to note:
Roof paint is fading
erinobr2000
