1998 SR5 Part out - Andrews AFB, MD
Well I scored a 1998 4runner for parts - unfortunately it is a very complete one that runs and drives... 202K on the clock. it is black with a grey interior -
I will be using the following parts:
Tow hitch
Front Spindles
Transmission
Transfer Case
Front Differential
CV axles
Front / Rear driveshafts
Rear Heat Option
Center console
ECU
Misc Wiring
Basically I am going to use all the parts to do a 4x4 5-speed swap on my other one...
Things wrong / damaged -
Front bumper and valance
front windshield (cracked)
Airbags deployed at some point
Other than that if people need anything just hit me up - with what you need and I will get back to you
Located around Andrews AFB, MD
is the interior the true grey or is it the moon mist blue-ish grey? I am looking for a glovebox door for my 01...let me know..
Grill seems to be intact. Looks to have originally been a grey but it has faded some but no visible cracks or damage.
Eh, nothing a little paint can't fix though. How much were you hoping to get for it? Would need shipped to 03820
condition of the interior?
I need two rear head rests, every single seat bolt cover, (front and rear, should be 12 total), and perhaps the trim panel that the driver's right shin rests on...the one next to and below the shifter bezel.
clear corner markers?
negative - driver's side is broken and passenger side is stock
To all above and PMs - I have not forgotten about you all - I have an intermittent work schedule and weather has not been helpful either - I began disassembling things today on the interior so verify if things are useable and in decent condition --- pics will be posted in this thread
whats the interior like???
interior is actually pretty decent - no tears or rips in the seats - door panels are good --- headliner is even nice... the carpet is of course a bit nasty - door panels and seats could use some cleaning but no signs of damage
So I am to a point of wanting to get a buyer lined up for the engine of this thing.... it has 202K on it but it does run and has no smoking or knocking - not looking to get rich - just figure someone could use it even if for parts
Any interested parties for the following?
- Interior door panels
- Seats front / rear
- dash frame
- doors
- body panels
- frame
- sunroof
- roof rack
- glass
I am just trying to gauge any interest in any of this stuff - otherwise it'll be going to the scrap yard -- I havent found any rust on the body - the frame seems to just have surface rust - I figure someone could use it ---
any interest?
- dash frame
- doors
- body panels
- frame
- sunroof
- roof rack
- glass
any interest?
Still interested in the grille if it's worth your time...
I need some interior stuff.
Both door panel tweeter mounts (black triangle) that sit over the side mirror bolts
arm rests off door panels all 4 if clean and tight fabric
small pieces here but the plastic pieces that hold the lock linkage tight at the rearmost portion of the door panel
also complete battery hold down assembly. the top bracket and rear-most anchor portion
98503 let me know how much
youngrk
