1999 Limited "Forerunner" Build
Here's my sub and amp set up.
And today before work I installed fog lights on my Addicted Offroad bumper and hooked them up to the existed fog light wires.
And during my lunch I installed an LED in the glove box where the existing light was. Also tried to replace the light for the cig lighter ring and I wasn't able to pull out the bulb and ended up breaking it. It's not even possible to replace the light. How were others able to replace theirs? Thanks so much!
Does anyone know how you turn the side corner lights on? I have never seen mine on ever! I don't know when they are supposed to be on. It could just be bulbs being blown but I don't want to spend money on bulbs that don't even turn on.
your marker lights should turn on with the first position of the left steering column stick and stay on when you turn your headlights on. The bulbs are easy to replace and check just pop the hood and unscrew.
I never knew that. Thank you so much!
they are white bulbs because the housing is both amber and clear. I have aftermarket LED's in mine that were still pretty cheap and are ten times brighter. The marker light bulbs are smaller then the three taillight bulbs. They are the same size as the license plate ones. So if you have license plate lights that work, try them in your marker lights to see if it is wiring or the bulb.
My license plate lights don't work either haha. Thanks for the help. I guess I'll end up buying the bulbs.
Where would a good place for a light bar be?
Red: 41.5" White/Amber Light Bar
-On Slag Factory Roof mounts
Blue: 21.5" White/Amber Light Bar
-Put in grille after cut
Green: 31.5" White/Amber Light Bar
-Using tube mounts mounted on bumper
So my lift says it fits up to 31x10.5. I cannot find any tire that will fit a 16" rim. I need to get tires next week. What is a good size tire that is similar in size to the 31x10.5? I have 265 70 R16 now. Any help would be highly appreciated. Thank you!
[MENTION=117428]skier46er[/MENTION], take a look at 265/75/16s. They might be around the size that you are looking for.
So today I went to open my tailgate and it didn't open at all. It seemed as though it is locked but won't unlock. I hit the unlock in the car and it still doesn't do anything. Anyone know what this could be?
She is all cleaned up to get her new shoes tomorrow. Going to be a little wider and not taller. I think it will look good. Will post photos as soon as I can.
Just installed LEDs in the DRLs so they finally work! I also put in resistors so the LED turn signals do not flash like crazy when I rarely use them haha.
Then I had to help my father build a bridge in his biking trails so i was able to take my car for a little expedition if you can call it that.
So here's a picture of the LED DRLs and I also decided to get rid of that old bug deflector. It just made the rig a family car still.
Sorry you can't see the LEDs that good. It's a beautiful day with a lot of sun. I will try to get a better picture at night.
Finally painted my rims today to get rid of the ungodly salt corrosion.
Before:
During:
After:
Also found out the a cover behind my rotors is rusted out.
