Mountain Fun
The Sky adapter is great but it will only work with a 1ton master. The push rod extender is designed for a master that has a hole in the main cylinder. The 1/2 ton doesn't have that hole, just a dimple which make the rod too long.
I mounted the adapter up to the booster and test fitted everything.
I bench bled out the master. This is a must or you won't be able to get all the air out. There are two common methods for doing this. You either use tubes that run from the master back to the reservoir. Or you can plug the holes and just keep cycling till all the bubbles are gone. I used the plugs since that is what my master came with.
Master all mounted. You can see the T100 front brake line I used here. I had to grind down the mount a little to make it fit but I'm pretty happy with the clean look.
