1st gear (lower) swap from 2005 to 2004--OR whole tranny?
Mako
Looking to maybe swap in the first gear from a 2005 V6 (3.5 ratio) into my 2004 (2.8 ratio). Anyone done this?
Or, can a whole 5-speed from a 2005 V6 be swapped into a 2004 without the dash christmas tree lighting up?
Thanks in advance,
Mako
any info
Does anyone have actual information? I would have the ECM from a 2005 for the swap, or ref lash my 2004. (Dealer says they'll do it).
Questions like will the A750F from a 2005 bolt up to the 1GR-FE in the 2004, or did bolt patterns change.
Then fitment, will the 5-speed fit where the 4-speed was.
Any help appreciated! Thank you.
You can't swap the 1st gear from the transmission because unlike a manual transmission the gears are not separate.
How Automatic Transmissions Work - HowStuffWorks
You can bolt the transmission up to the 1GR-FE, but I don't know how different the harness, ECM pins, and connectors are. You may be able to reflash the ECM (I don't remember how flexible the ECMs are in that respect as we don't do it often.) You may find that it may be cheaper to trade the vehicle in for an '05.
Tx470
