1st gen overheating, newly replaced cooling system parts
So after installing the new fan clutch I have a little bit of slight rough idle at start up that lasts about 30 seconds and goes away, and every now and then at a stop light. Am I having head gasket issues or is this just because its cold outside and the oil needs to warm up. Btw I don't have any oil in the coolant and vice versa, I also dont see white smoke from my tail pipe and im not having CONSTANT over heating issues, I also changed my brake booster, plugs, wires, distributor rotar and cap not too long ago so I doubt its that. What could be causing this slight rough idle?
After researching a bit more im wondering could this be a cold start injector problem?
Okay, cool. I thought I'd seen a writeup where somebody used a meter to check resistance through the therm at different temps. If it's all mechanical I must be thinking of something else.
You can check the resistance of temperature sensors from cold to hot temps to verify that they change resistance at the manufacturer specified scale.
Laredotx
