#2 ABR Sidewinder Group buy #2
shawn719
Ok, I've had a couple PM's on this. So, since the last group buy went so well I am willing to do this again.
I am only facilitating, not ordering or making profit - this is all you.
Probably need at least 12 members on this to make shipping worthwhile.
I will take the lead and make payment and accept delivery and then deliver to you via USPS or meet you within a reasonable commute from Derby, Kansas
I will keep all vested members included on all to/from ABR emails once the process starts rolling.
Take a look at the website (he has a lot of gear) and make your list. I will keep one rolling post with all requested items per member. (Please no battery cables as the cost to ship is $ counterproductive.)
Popular items have been the aux battery trays, Sidewinder kit, and the type-1 Toyota switches...
Place a tentative date of May 12 (4 weeks-unless agreed to end sooner to place order) to have all requests in. You will need to pay up front for items before I place your item(s) in the final request.
Once finally gear tally has been made I will get final shipping amount and divide amount by all who have placed order.
Once final funds are received I will send order in and wire money to ABR.
Here is ABRs website,
http://www.sidewinder.com.au/
Chime up so I know if you are interested.
S
MAJOR props to Shawn for doing this. I was in on the first buy for just a few switches and it could not have gone smoother. You're a class act Shawn, thanks for helping the community here :rockon:
what is the advantage of the sidewinder?
Yes, Sidewinder is the brand; however, if you are asking about the battery isolater (automatic one), here is the information (found on website).
"DUAL BATTERY CONTROLLER
12V 140 AMP (400A Surge) FULLY AUTOMATIC
BUILT IN SPIKE AND SURGE PROTECTION
FULLY AUTOMATIC CONTROL ISOLATES
STARTING BATTERY WHEN ENGINE
IS NOT RUNNING. ‘R’ TERMINAL FOR
REMOTE MONITORING AND OVERRIDE.
Never have a flat battery again.$79.95"
I have mine installed and it helps me take out all the guess work of having the AUX battery in place. The unit is quality made, easy to install, and works as advertised (and the price is good too).
S
[MENTION=49690]shawn719[/MENTION] ... what was the group buy price for just the battery tray alone? i never could figure that out from the last thread. you can PM me if you want. thx
Questions
Thanks for offering this Shawn, I'm a long time lurker, and this opportunity pushed me to register (as well as my upcoming build).....I'm a former 6 speed forum and current DIYMA member, with an excellent reputation. I've read your build log (and several others). I'm most interested in replicating your ARB set up (copy of a copy-ha). That said, what is your review/feedback after having it installed, anything you would recommend/ do differently? Thanks!
I'm a 2011 TE guy.....
For the tray, shipping, and 10% discount it came out to be $186.50 (that was with approx 12 people ordering parts). The tray is high quality, matches perfectly, and heavy duty.
I would reccomend the Type 1 Toyota switches as they match perfectly yo switch locations on dash.
I was very pleased with the previous group buy, Shawn does a stellar job.
That being said, If this takes off I'd be interested in a few switches. Will have to take a look and see how many.
I really want one of these trays.......
I just can't get past the price. $139.95 on the website. WOW!
That's pretty steep to begin with for Battery tray that probably costs about $10-$15 in materials to make
But then...on top of that, It really cost $46.55 to ship a 3-4 lbs package to the USA????
A quick check of the USPS.com show a 20lb box to Australia is $79.95, you got to be able to fit more than 2 trays in that box.
Yes I realize that is from the USA to Australia, but I think it's at least comparable coming this direction.
I also understand there is an exchange rate difference...$1 USD = $0.95 AUD
I'm just trying to justify this.....Can someone help me understand?
Thanks and welcome to the forum!
I like the setup and there is little I would change.
-The Optima batteries are a great match and fit - no complaints or powering issues. I wanted to ensure I had enough juice to run my XRC10 winch without tasking out main power draw.
-The ABR gear is solid, well built, and easy to install (instructions are well laid out and easy to follow).
-The tray is heavy duty and is worth the cost (IMHO) - especially compared to the plastic tray the main battery sits on. The tray drops in to place and bolts down with supplied hardware to existing threaded holes. The instruction and gear for power reservoir relocate matches and is easy to do.
-The Sidewinder AUX battery switch is a no brainer. Easy to mount, hookup, and it does the rest (monitors voltage and switches battery power as necessary).
-The battery monitor is a nice feature and provides me with voltage on both batteries and option to switch over to AUX in case of emergency power is needed, etc.
-I did run new power cables to winch since I had to relocate winch control box. I replaced 4 gauge with 2 gauge wiring.
-I ran 00 gauge wire from main to aux battery for power. A little overkill - If I had to do over I would run 0 gauge cable. The 0 gauge, easy to work with and ring connectors are easy to come by, etc. I may repull 0 gauge to replace 00 gauge.
-I did replace the "L-Shaped" positive battery terminal on the AUX battery with an X-Scorpion battery terminal. The wires I running to L-shpae were hard to work in confined space, and I was worried about rubbing and an eventual short. The L-Shape was also hard to work with where the positive post is located on the Optima Yellow battery. The X Scorpion is a perfect fit and has multiple wire mounting locations (for different gauges). There is also a LED voltage readout, (still no sure if I am going to hookup). Here is a vid I found on YouTube of the X-Scorpion terminal: X Scorpion Battery Terminal
-I am in the process of the clean up and organization (tie wraps, wire loom, etc.). Would have been nice to run all wire first, wrap, tie, label, etc. This would have made the job easier and faster to accomplish. Of course, this is a wish as things change during install as I added, changed, and moved components as the install went along.
Yellow Top w/ABR neg term and XScorpion positive term and ABR Sidewinder aux battery tray
Red Top w/ABR L-Shaped positive term (100 amp fused) and ABR neg term.
I have switch breaker temp mounted w. tie wraps until I can find a more perm location or I might velcro down.
Pic of Sea aux fuse box and XRC10 winch control w/ OTRATTW switch
The bay
The shipment is not via snail mail - meaning weeks or so for delivery. The items are delivered in a week. So there is expedited shipping involved.
Granted, this is not for everyone - if the price point does not match your desire then there are many other options to work from.
I have no complaints - and that is after making the first order solo, for my own gear. I am happy and have no regrets.
I know in the past Derek Bester has been burned on international orders to the U.S. Hence the reason why he prefers not to work directly w/ U.S. via his website or eBay. (A few losers out there ruining it for the rest I suppose)
Again, from what I have gathered, no one has had regrets from their order. So, that leaves something to be said.
Ultimatley, its a personal choice/desire. To Justify? Is it necessary to purchase for the T4R? No, of course not - just one of those nice extras to have. :rockon:
Orders
Chitown4x4
1 x 2010 FJ Cruiser tray
4 x Type 2 Toyota Switch
BJ Cruiser
2 x Prado LC150 Battery Cradle
2 x Dual Battery Isolator
TexasAg
?? (What are you looking to get)
BTW - I met [MENTION=49690]shawn719[/MENTION] tonight on a completely unrelated mission. Lessons learned:
- He's a marine...still deciding if that's bad.
- He's energetic...very energetic.
- His truck ('10 and 56k miles) is cleaner than mine ('12 and 30k)
- Trustworthy
Ryan,
Good times - even though I kept calling you "John":blabla:
Till next time! Semper Fidelis
delislerebecca
