2 In 1 Key Fob 4Th Gen
Got the remote and key programmed without issue. Just need to get the key cut now (you can program the key without having to cut it). Going to Lowe's to have it cut for free!
Everything work well with the key now? I may have to order one for my '03 if it works (I'm assuming the 03 and 04 are the same)
Would this work with the remote start systems that work with toyotas by pressing the lock button 3 times to start the car?
I was actually wondering the same thing. I assumed that it would. I am thinking about trying this in the spring. If you beat me to it, let me know.
You can try it out first, I'm still on the fence about remote start..
How can I find my FCC ID if I don't have the original fobs? My truck came with some aftermarket remote start/door lock remotes.
It should be? Or are you just guessing...
Not really guessing, that's what it is for my 2004 OEM fob and looking for a OEM replacement fob for mine so I have an extra shows that it's the same number for a 2003, but I suggest that anyone do their own research online for a OEM 2003 replacement to put their mind at ease!
All I was getting at is, mine is BBX that's all...
Yes from my research HYQ12BBX is the correct number for 2005 to 2009 4 Runner key fobs, but not for a 2004 which is as stated is definitely HYQ12BAN and from what I've seen online is the same for the 2003.
2003 Successful
Just wanted to say thank you and that this worked for my 2003 Sports Edition 4runner. No idea what my FCC ID is, just took a chance and all is great! F.Y.I. my local Lowes and Wal-Mart would not cut the key as they stated it was strict policy not to cut any key key provided by the consumer as they would be liable if it broke my key. My local locksmith cut it for me no problem with a copy of the master key in about 60 seconds.
Will one of these work instead of the switchblade style?
Also, will this one work? I prefer the look of the one the OP used.
http://www.ebay.ca/itm/ALLin1-USA-C...ash=item5441ccaa13:g:cHoAAOSwMVFXHr7N&vxp=mtr
The "non-flip" key like the one in the picture you posted is available for our trucks from the same seller we have purchased the "flip" style from. It's just personal pref. on the style you want to go with.
The link you posted is diff from the pic you posted and the flip style that we are using. I can find the link to the non flip on you are asking about.
Inaugural Update
3 months in and this thing is still great and the included batteries are still going strong. :lookout:
We have had ours for a month or two now and have had no issues. it works better than my replacement fob that I got from the dealership!
The only issue I found was getting someone to cut it. Lowes and HD wont do outside keys for liability reasons. most of the locksmiths I contacted had a newer style of machine that didnt allow for the fob.
Does the fob allow for you to take the key blade itself out? I recall the other ones I played (Audi, Acura, Ebay one I used for my Si) with had the key blade on a spring if opened up. That should allow it to fit on the smaller key cutting machines.
How did you order it? Did you use the eBay link but directly message the guy to request one using the FCC code of our particular model year?
I have not tried, because I have not had to take it apart yet...[emoji23] It wouldn't be as easy as just pressing a clip to pop the key out like on some though...
Post #74 [MENTION=22393]Wallace[/MENTION], did seem to be able to take the fob apart to make it smaller to fit in the machine by the sounds of it.
